I was investigating Joystick module driver when I found a few interesting bits that I would like to point out.
- In 4.3 version there is line:
I think it should be:
```cs]socket.EnsureTypeIsSupported('A', this);[/code
2. There is no [em]EnsureTypeIsSupported[/em] check in 4.2 version.
3. Is it really necessary to do 20 readings (10 readings per axis) to get accurate joystick position? Maybe 3 readings per axis would be more than enough? Doing so could increase the performance.
