I have connected the Joystick to FEZ Spider and doing some basic writing on the Display but the events are not fired when i move the joystick, what could be the reason
@ irizvi - The JoystickPressed and JoystickReleased events are specific to the joystick’s built-in button (that is, if you press downward on the joystick, as opposed to deflecting it to the side, it will “click” and the JoystickPressed event will be raised. When you release it, the JoystickReleased event will be raised).
If you want to get the value from the joystick, you need to use the following code, usually within a timer:
Does it make a big difference to use a thread vs. a timer to poll the Joystick position? I’ve not tried it using a thread, just using a timer, which has generally been adequate for my needs.
