Perhaps it’s because it’s not a classic “NIC”, but shouldn’t the “connected” indicator go out when no Ethernet connection exists (cable disconnected)?
Also, are there plans for “NetworkConnected” and NetworkDisconnected" events in a future SDK?
These would go a long way toward event-driven network apps.
[quote]Perhaps it’s because it’s not a classic “NIC”, but shouldn’t the “connected” indicator go out when no Ethernet connection exists (cable disconnected)?
[/quote]
Do they blink when connected ?
[quote]Also, are there plans for “NetworkConnected” and NetworkDisconnected" events in a future SDK?
[/quote]
I beleive that his has been demonstrated on several applications.
The “activity” indicator blinks green when an active cable is connected and traffic is seen on that connection.
The “connected” indicator remains solid yellow regardless of cable connection or traffic state.
What’s the easiest way to verify the Ethernet is working? It was sending and receiving fine,
Now nothing can be received, not even an ip address with DHCP.
Create new project. Copy code blocks out of supplied project (notepad is your friend for opening the .CS files) and paste into your new project. Removes the concern of old SDK references that opening someone else’s project would have included.
