i want to make Di8 as InterruptPort on Domino, and can someone help me
not possible. Check the Domino documentation, the pinout map clearly states DI8 is not interrupt input capable.
tnx
and one question, i want to read analog input size with 0 to 12V, and also is this possible?
Sure, by using a voltage divider : only 2 resistors !
Look here for information : Voltage divider - Wikipedia
Since the analog pins reads voltage from 0 to 3,3v, you will need for your example to use a 4x factor;
With real world resistors values, for Z1 you can use a 3,3K resistor, for Z2 a 1K resistor, and you will be able to read from 0 to 14 volts.
Connect Vout to your FEZ board analog pin, and Vin is your probe…
http://www.raltron.com/cust/tools/voltage_divider.asp
tnx very much, but has someone example, need help
May I suggest you run through [url]GHI Electronics – Where Hardware Meets Software first?
Then to read analog inputs: [url]GHI Electronics – Where Hardware Meets Software
Greetings.
