Hi
My laptop is connected to our company internal network and I attached an image which shows my network configuration
I also connected the FEZ device to a switch of the network and I can ping the FEZ device through the command prompt on my laptop .
I have written a UDP Sender Gadgeteer application which code is as follows :
string[] dnsAddresses = { "172.16.40.2", "172.16.40.5" };
InitEthernet();
BlinkLED();
SendUDPMessage();
private void InitEthernet()
if (!ethernet.Interface.IsOpen)
ethernet.Interface.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(ethernet.Interface);
ethernet.Interface.NetworkInterface.EnableStaticIP("172.16.43.193", "255.255.255.0", "172.16.43.254");
ethernet.Interface.NetworkInterface.EnableStaticDns(dnsAddresses);
private void BlinkLED()
multicolorLed.BlinkRepeatedly(GT.Color.Purple);
private static void SendUDPMessage()
int numOfUDPMessagesSent = 0;
Socket socket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
IPAddress DestinationIP = new IPAddress(new byte[] { 172, 16, 43, 175 });
IPEndPoint DestinationEndPoint = new IPEndPoint(DestinationIP, 2000);
byte[] buf;
for (int y = 0; y < 1000; y++)
Thread.Sleep(2000);
buf = Encoding.UTF8.GetBytes("Hello World from FEZ Spider" + y.ToString());
try
socket.SendTo(buf, DestinationEndPoint);
numOfUDPMessagesSent += 1;
Debug.Print("Num of udp sent : " + numOfUDPMessagesSent.ToString());
catch
when I deploy It to the FEZ device in the output window I see the messege : “Num of udp sent : i”
which meens that UDP Packets our beeing sent on the network to my laptop cause the DestinationIP is my laptop IP in the network .
after that I tried to write a simple console application and run It on my laptop to receive UDP Packets being sent by the FEZ device gadgeteer application .
Here is the code of this console application :
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Net.Sockets;
using System.Net;
namespace UDPReceiver
class Program
static void Main(string[] args)
Socket serversocket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram,
ProtocolType.Udp);
EndPoint ServerEndPoint = new IPEndPoint(IPAddress.Any, 2000);
serversocket.Bind(ServerEndPoint);
int i = 1;
if (serversocket.Poll(-1, SelectMode.SelectRead))
EndPoint recEndPoint = null;
byte[] inBuf = new byte[serversocket.Available];
int count = serversocket.ReceiveFrom(inBuf, ref recEndPoint);
Console.Write(Encoding.UTF8.GetChars(inBuf));
Console.Write("From" + recEndPoint.AddressFamily.ToString());
Now here is the issue : when I run this console application and try to receive the UDP Packets sent by FEZ device
at this line of code :
I get the error which sais the second parameter of ReceiveFrom function which is remoteEP is null .
what should I do ? thanks in advance .
