Hi , I have developed a gadgeteer app running on fez spider
I have used an Ethernet module by wich I connect the fez board to my laptop
in my ProgramStarted() function I use an InitEthernet function as follows :
public void ProgramStarted()
InitEthernet();
and here is the InitEthernet() function :
private void InitEthernet()
try
if (!ethernet.Interface.IsOpen)
ethernet.Interface.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(ethernet.Interface);
ethernet.Interface.NetworkInterface.EnableStaticIP("172.16.43.193", "255.255.255.0", "172.16.43.254");
ethernet.Interface.NetworkInterface.EnableStaticDns(dnsAddresses);
catch { }
now here is my issue :
I do the following steps :
1- Plug the Ethernet cable into the Ethernet module
2- connect the usb client to my laptop
3- I compile the application using visualstudio
in this scenario the application compiles and I can see everything on my lcd
BUT !
when I do the following scenario the application does not compile and nothing appears on the LCD Module :
in the second scenarion I want to run the application without compiling It using Visual studio ! because I have programmed the board following the first scenario the last time but Its not possible !
to solve the issue in the second scenario I tried the following :
1- Unplugged the Ethernet cable from Ethernet module
2- connected the usb client to my laptop
in this third scenario the program runs on fez board and all the GUI I have applied appears on the LCD Module ! and after It appears I plug in the Ethernet cable and the connection to my laptop starts and I can ping the device !
So as far as I can guess there must be something wrong with the Ethernet module . I wonder what this issue is that if the Ethernet cable is plugged into the Ethernet module the program can’t run on the board without being compiled from visual studio !
any helps would be appreciated .
