Well, well, well. Guess what the problem was. The connector on the green breakout board differs from the one in the box. It seems I was plugging in the wire upside down. I am now able to get touch input. On to the next issue. “How to touch Avalonia”
Edit: The image shows the correct way. Also, the seller confirmed that the additional power pins must also be connected.
Well, Avalonia touch works.
var input = new InputDevice();
var touch = new FT5xx6Controller(EPM815.I2c.I2c6, EPM815.Gpio.Pin.PA4);
touch.TouchUp += (s, e) =>
input.UpdateTouchPoint(e.X, e.Y, GHIElectronics.Endpoint.Drivers.Avalonia.Input.TouchEvent.Released);
touch.TouchDown += (s, e) =>
input.UpdateTouchPoint(e.X, e.Y, GHIElectronics.Endpoint.Drivers.Avalonia.Input.TouchEvent.Pressed);
I did mention somewhere: “if the connection is correct…” :d
I was so sure it was plugged in. Then, I looked at both connectors and realized the pins were in different places. Also, all the GNDs and VDDs needed to be connected. That was super confusing as well.
