as the title, is that the spider can using serial camera? i have try to used a serial camera in spider , but very strange, sometimes the spider can recieve the response from camera after sending a reset command, but sometimes it can’t, i also used a oscilloscope to check the signal, i found that when the spider only connect the TX to the camera, the signal from TX and RX are normally, but after connect the RX to the camera, neither the signal from TX or RX are stop, besides, i also try the level-shifting, but it still can’t work well. anybody can help me? thanks a lot!
Yes it should work. I remember seeing example on code share.
thank you for help!
