Hi guys.
i would like to get the most from the RS485 Module.
I’ve 3 Gadgeteer boards connected with RS485 module.
I don’t want to reinvent the hot water, does exist an IP stack implementation that runs over this serial bus?
Does mIP would work? does exist a driver for RS485 and boards like cerberus and hydra would be able to manage such stack?
PPP for 2 points but not sure about multiple points.
I am sure you can modify mIP to make it work
@ Gus - About the PPP, I don’t recall ever finding a solution to this, but is there a list of the PPP commands that you guys implemented? Surely there is a pdf you all used that can be shared.
@ Mr. John Smith - We used PPP that was present in the lwip stack.
