With over 6 years of great success, The EMX System on Module (SoM) has been one of our most successful products. Today, we bring you the next generation of the EMX SoM, named G120E.
The G120E SoM is a drop-in compatible upgrade for the EMX SoM. It runs at 120Mhz instead of 72Mhz and uses a Cortex-M3 instead of an ARM7. Applications will now run twice as fast with very minimal software changes. Also, unlike EMX but similar to G120, the G120E is going through CE/FCC testing.
The G120E and G120 SoMs both run the exact same software (requires SDK 2015 or newer). The main difference between the two products is that the G120E SoM includes an Ethernet PHY on-board and has more IOs. Using the same firmware allows us to focus better on adding features and improving the quality of the software.
Now to the best part, G120E SoM is priced at the same price as the EMX SoM. In other words, products running EMX SoM can now run twice as fast with the G120E SoM without any cost increase, utilizing a CE/FCC tested SoM!
The G120E Development System is the perfect place to start evaluating the G120E SoM. With all the features exposed, developing applications on the G120E Development Board saves a lot of time and shortens the time to market. This board is also useful for evaluating and developing for the G120 SoM, as the G120 and the G120E are nearly identical.
For current EMX SoM customers, no worries, the EMX SoM will be available through 2015 and will be slowly phased out in 2016. If you have any needs beyond 2015, please contact us with details on your product. Of course, the G120E SoM will just drop in your product so no hardware changes should be needed. However, some very minor changes will be needed in the software. You will also be required to use the 2015 SDK. We are also available to assist you in the upgrade process.
Public availability of the G120E and the G120E Development System is expected by mid 2015. Current 2015 SDK already supports the G120E SoM.
*** EDIT *** The G120E also includes a 32kHz crystal allowing for more pins to be exposed.
G120E SoM: http://www.ghielectronics.com/catalog/product/532
G120E Development System: http://www.ghielectronics.com/catalog/product/533
G120 SoM: http://www.ghielectronics.com/catalog/product/373
G120E Preliminary Brochure: http://www.ghielectronics.com/downloads/man/Preliminary_G120E_Module_Brochure.pdf
