Morning folks. Last night I had my robot responding to an interrupt whenever the encoder pulsed which would simply (leftEncoder++;) increment a counter. I would have the program send send the counter (leftEncoder.toString() out the XBEE. All seemed fineā¦ rotate the wheel and see the count on the XBEE comms. However after a few minutes, the Fez seemed to lock up.
The only thing I can think of at this time is perhaps this is caused by reading a value that is being modified by another thread. Am I way off base here or not?
For reference, I donāt believe its the XBEE as I have sent gps data out it for hours with no problem.
Increment is both a read and a write which is *not thread safe. At least in .Net. In netmf, I assume same, but not much writen on the memory model.
The āincrementā is not atomic. A write to an int is atomic - which means different threads will not see a ātornā read, but the read-write operation in total is not atomic. To be fully atomic, use a lock or Interlocked.Increment. Your interupt is on another thread (set a Debugger.Break() in your callback to see all the threads).
Doesnāt really answer the original question but the Interlocked.Increment and Interlocked.Decrement static methods in System.Theading should be thread safe and (supposedly) fast.
