I have a bumper (see image) in my Cerbuino Bee.
I had it implemented as InterruptPort but now every time I click it it exits the program. In debug mode it doesn’t enter the event.
private static InterruptPort rightMoustache;
private static void moustache_OnInterruptRight(uint port, uint state, DateTime time)
Debug.Print("Bigode Direito");
rightMoustache.ClearInterrupt();
Debug.Print("Start");
const Cpu.Pin rightMoustachePin = FEZCerbuino.Pin.Digital.D10;
rightMoustache = new InterruptPort(rightMoustachePin, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow);
rightMoustache.OnInterrupt += moustache_OnInterruptRight;
Either create you app using Gadgeteer
or
Add
at the end of Main routine
This how i would do it using a Gadgeteer project…
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
private InterruptPort _rightMoustache;
_rightMoustache = new InterruptPort(GHI.Hardware.FEZCerb.Pin.PA15,true,Port.ResistorMode.PullUp,Port.InterruptMode.InterruptEdgeLow);
_rightMoustache.OnInterrupt += rightMoustache_OnInterrupt;
void rightMoustache_OnInterrupt(uint data1, uint data2, DateTime time)
_rightMoustache.ClearInterrupt();
It worked! Thanks @ Bill Gates
I’m using a NETMF project and I’m using 2 bumpers to decide the behaviour used by the robot.
@ codewizpt - yr welcome, look forward to seeing the robot
Another option, if your device is battery powered you might want to put the processor to sleep when you’re not using it…
Microsoft.SPOT.Hardware.PowerState.Sleep(SleepLevel.DeepSleep, HardwareEvent.GeneralPurpose);
Your device will automatically wake up instantly when the interrupt fires. You shouldn’t notice a difference in performance but you will save some battery power.
Thanks, untitled. I will try, though I have a LiPo battery
