Interrupt not firing
I have a very simple button class that uses an interrupt port to raise pressed and released events for a hardware button. Button.State reports accurately, but the interrupt never fires. Can someone look at my code and see if I’m making some stupid mistake somewhere?
public class HardwareButton
    private InterruptPort port;
    public delegate void OnSwitch(HardwareButton sender);
    public event OnSwitch PressedEvent;
    public event OnSwitch ReleasedEvent;
    /// <summary>
    /// Gets or sets the input state considered to be active
    /// </summary>
    public bool ActiveState { get; set; }
    /// <summary>
    /// Gets the current state of the button
    /// </summary>
    public bool State { get { return port.Read() == ActiveState; } }
    public HardwareButton(Cpu.Pin input, Port.ResistorMode resistorMode = Port.ResistorMode.Disabled, bool activeState = false)
        this.port = new InterruptPort(input, true, resistorMode, Port.InterruptMode.InterruptEdgeBoth);
        this.port.OnInterrupt += inputPort_OnInterrupt;
        this.ActiveState = activeState;
    private void inputPort_OnInterrupt(uint port, uint state, DateTime time)
        DebugHelper.Print("Button triggered");
        if(this.State)
            if (this.PressedEvent != null)
                this.PressedEvent(this);
            if(this.ReleasedEvent != null)
                this.ReleasedEvent(this);
When I try to validate the interrupt port in a test project it works.
public partial class Program
        InterruptPort port = new InterruptPort(GHI.Pins.G400.PA22, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeBoth);
        port.OnInterrupt += port_OnInterrupt;
    void port_OnInterrupt(uint data1, uint data2, DateTime time)
        Debug.Print("Triggered");
I can’t see the difference in InterruptPort implementation.
How do you use your HardwareButton? Is it possible that it is instantiated in a local scope and got garbage collected?
The HardwareButton instance is being instantiated inside a Singleton class with no chance of being garbage collected. As I mentioned in the top post, the Button.State member is reporting correctly. It is just that the interrupt itself is never firing.
The only other difference I see is the default parameter for pullup is Disabled in your class constructor and the second example uses PullUp.
@ bigtwisty -
not sure but look like you are missing:
@ Dat:
My original version had EnableInterrupt() and it still didn’t work. Non of the examples on your site used EnableInterrupt(), so I removed it. The test application in the OP does not use EnableInterrupt() either, but it works.
Edit @ Architect:
The demo was written to duplicate the actual instantiation in the Singleton class, so the pin and pullup are set identically in both apps.
Edit:
Solution found! I moved the button to GHI.Pins.G400.PB5. The original pin (PA22) can be used as SPI2_MOSI, but I am not using SPI2 at all. I was under the impression that all pins supported interrupt functionality. If this is not true it should probably be documented somewhere.
Thanks for the responses, guys!
