What I want to do is:
[ul]Precompute an array of values and store it in memory, using managed code[/ul]
[ul]Set up a native code routine to be run at 10ms intervals[/ul]
[ul]On each run, output the next value from the array[/ul]
So where do I get started with:
[ul]Choosing/allocating a suitable area of memory, and accessing it from the managed code[/ul]
[ul]Setting up a timer, or a high-priority interrupt driven from an external signal[/ul]
[ul]Accessing the memory region from the interrupt routine[/ul]
[ul]Accessing some output pins from the interrupt routine.[/ul]
Does any part of the system run a top-priority interrupt that may interfere with or delay the execution of my routine?
I’m using a Raptor, although I’d like as much of the work as possible to be portable to other processor boards.
Thanks, Phil
