I am trying to abstract my program so that it will run on both a G120E and a G400S without modification and have made good progress but in order to make things easier I am wondering why the J11D, ENC28 and wifi adapter drivers don’t share a common interface, e.g.
INetworkAdapter networkAdapter;
switch (Mainboard.MainboardName) //SystemInfo.SystemID.Model
case "GHI Electronics FEZ Spider II": //14
factory = new Mainboards.G120_SpiderIIFactory();
networkAdapter = new GTM.GHIElectronics.EthernetJ11D(factory.GetMainboard().Ethernet);
break;
case "GHI Electronics FEZ Raptor": //9
factory = new Mainboards.G400_RaptorFactory();
networkAdapter = new GTM.GHIElectronics.EthernetENC28(factory.GetMainboard().Ethernet);
break;
default:
break;
if (networkAdapter.NetworkInterface.Opened)
networkAdapter.NetworkInterface.Close();
networkAdapter.UseThisNetworkInterface();
or am I looking at this in fundamentally the wrong way?!
@ networkfusion - The underlying drivers in GHI.Networking all derive from BaseInterface. The Gadgeteer modules do not since they compose instead of inheriting from the underlying drivers. They do derive from Gadgeteer’s NetworkModule, though.
@ John - private Gadgeteer.Modules.Module.NetworkModule ethernet; would get me part way there but the problem is initialising the driver since there is no access to any of the following commands:
specifically the last one… I am thinking of adding a wrapper to the module drivers, but this adds extra complexity:
using SensorNetNode.Mainboards;
namespace Gadgeteer.Modules.NetworkFusion
public class EthernetENC28 : INetworkInterface
Gadgeteer.Modules.GHIElectronics.EthernetENC28 ethernet;
public EthernetENC28(int socket)
ethernet = new Gadgeteer.Modules.GHIElectronics.EthernetENC28(socket);
public void UseThisNetworkInterface()
ethernet.UseThisNetworkInterface();
public void Close()
ethernet.NetworkInterface.Close();
public bool Opened {
get
return ethernet.NetworkInterface.Opened;
set{}
@ networkfusion - Unfortunately we do not control Gadgeteer.Modules.Module.NetworkModule, which the Gadgeteer networking drivers derive from.
You do not have to use the Gadgeteer module drivers, though. You can use the classes in GHI.Networking yourself which all derive from BaseInterface, provided you pass them the correct pins.
@ John - ok, thanks for your input. I have gone down the route of doing it like this:
class G400_Raptor : Mainboard
public override Sockets Socket
get { return new G400Sockets(); }
public override void ConfigureNetworkInterface(byte[] macAddress)
var eth = new Gadgeteer.Modules.GHIElectronics.EthernetENC28(Socket.Ethernet);
eth.NetworkInterface.PhysicalAddress = macAddress;
if (!eth.NetworkInterface.IsDhcpEnabled)
eth.NetworkInterface.EnableDhcp();
eth.NetworkInterface.EnableDynamicDns();
eth.UseThisNetworkInterface();
It may mean a repeat of code for all drivers (except new Gadgeteer.Modules.GHIElectronics.EthernetENC28(…), however it is the only way I can find to enable the adapter without getting into a chicken and egg situation with the MAC.
@ andre.m - Okay thanks for pointing out that I used the wrong G400 type, changed the G400D to a G400S in the first post, but since all of my code examples had “Raptor” and “Spider” in them hopefully everyone understood what I meant.
I plan on moving away from the gadgeteer platform to a more pure NETMF based one once I have finished prototyping but the sockets and their mappings are convenient and since I require the ability to swap sensors that can use different types of interface (SPI, UART or GPIO) so when I do, I may well have to reinvent the wheel anyway.
