Installing OSHW
I’ve got a project that references OSHW (GHI.OSHW.Hardware), and I’ve found the library on https://ghiopensource.codeplex.com/ but I don’t know how to install the library. Any hints? Seems like this should be a trivial task. Am I missing something?
further, the “library” is in the firmware on your device, and it needs to match the version you’re using on the PC, so once you install the SDK you should apply the firmware that the SDK came with on your device. But please also confirm, what device you’re talking about? OSHW is only for Cerb-family and Hydra devices from GHI, not Spider/G120
I had the “GHI Software Package v4.2” installed but not the sdk. Everything is working now. Thanks.
