is anything seen in Device Manager? An unknown device ? It is extremely unlikely that a device won’t show up at all, unless there’s a fundamental breakdown in the USB communication, so I’d try replacing the USB cable as a test.
Brett
Nothing is seen in device manager. However there is one unknown device, which I think appeared when I installed some IOT software for the Galileo. See image
I did try different cables and I plugged them into different USB ports on my PC
At a minimum, without any software installed, you should get an unknown device in Device Manager if they’re working correctly and presenting themselves to the USB port correctly.
It may be possible they don’t have a firmware on them. Can you test booting into loader mode (I don’t have a cerbuino so can’t tell you how, but https://www.ghielectronics.com/docs/46/fez-cerb-family-developers-guide will help) . You may then see a “serial camera detect” device with a COM port assigned to it if the bootloader starts successfully. That will at least tell us that the device is responding appropriately.
I wasn’t expecting the boards to be shipped without any firmware, especially as they are specifically targeted at .net MF.
Now back to my windows 8 system, I still cannot get this to work. In fact I get an application error whenever I try to run the STDFUTester (see image). I am going to roll back my windows 8 system and retry the install. I will add a progress update later.
@ BriK - I believe that error is caused by you not having the correct Microsoft Visual C++ redistributable version installed. I cannot recall which exact version you need (I want to say it is 2005), but if you look in the Windows Event Viewer, under Windows Log > Application, you should see an error relating to the dialog you saw. It should give you more information about which version you need.
Try to start the program and then immediately look in the event viewer so the error is right at the top.
I would have expected that to be a dependency of the installer.
So to get my system working;
I un-installed all of the .net MF and gadgeteer software then I rolled back windows to an older restore point.
After a couple of attempts at reinstalling the software along with the c++ re-distributable, I finally got the system working.
I then loaded the firmware onto my second device (as explained in my earlier post).
