I found a reproducible issue in TinyCLR related to events using Action<T> and inline lambda handlers.
Problem Summary
When an event is declared with Action<T> and I attach an inline lambda as the handler, deployment fails with an MMP error. The device (FEZ Feather) gets stuck during deploy.
Fails (inline lambda):
public event Action<BDEFrameEventArgs> BDEFrameDecoded;
bde_.BDEFrameDecoded += (arg) =>
// handler code
Deploy output:
Code
Failed to generate device specific assemblies:
Wrong type in blob: 1d
Unable to read value 0: 1d
Invalid blob:
MMP: error MMP0000: 0x81010002
Works (normal method):
bde_.BDEFrameDecoded += BDE__FrameDecoded;
private void BDE__FrameDecoded(BDEFrameEventArgs arg)
Notes
It looks like the metadata processor (MMP) can’t handle the synthetic types generated by inline lambdas when used with generic delegates (Action<T>). Using a named method works fine, so the issue seems specific to lambda expressions attached to Action<T> events.
Environment
TinyCLR OS
FEZ Feather
Visual Studio
C# event with Action<T>
Just wanted to report this so you can take a look. Let me know if you need a minimal repro project.
You are using the new stuff I see. That is great. We will look into this.
We found a case that may cause your issue and fixed it. Please update the extension to v3.0.1.6001 (Visual Studio usually updates it automatically if that option is enabled). Nothing else needs to be updated — firmware and libraries are unchanged.
If it still happens, please post a simple project here so we can try it, but your issue is most likely addressed.
Hi Gus, hi Dat,
just a quick follow‑up:
I can confirm that with the updated TinyCLR extension v3.0.1.6001, the issue with inline lambda handlers on Action<T> events is fully resolved. Deployment works flawlessly now, and the device no longer freezes during the MMP phase.
This now works as expected:
// lambda handler now deploys correctly
Thanks for the extremely fast turnaround — impressive work, especially on release day.
Additional note (unrelated to the fix):
Thread creation using a lambda has always worked fine, even before the update.
Example from my VFD task:
Thread vfdThread = new(() => vfd_.Run());
vfdThread.Start();
No issues there — just mentioning it for completeness.
Thanks again for the quick fix and for delivering a rock‑solid TinyCLR 3 release…
And also thank you for giving us a detailed report. This makes our work much easier.
