Where do you get this file from???
It is imperative that the SSL seed and its assigned MAC is not wiped from the device when it is updated (which is why I am guessing you need the file mentioned above), is there some code to copy out the configuration part of the flash and reinsert it once the update is completed?
@ networkfusion - The LoadFile function is defined in the Getting Started code example on the document you linked. When loading the configuration, the SSL seed and MAC address will be reset. You can read the MAC address, save it to an SD card or some other form of external storage, then reload it on the next reboot. For SSL seed, I am not aware of any method to set or read it from code so you cannot save it.
I understand the LoadFile function, but not where the “Config.Hex” file comes from? (MFDeploy only generates the [firmware].hex)
Is the SSL seed not saved within the “Config.Hex” file?
If the SSL seed cannot be set from code and if it cannot be set from a config.hex file, I am guessing that infield updating is out of the question as we will rely on the ability to connect to an SSL connection (azure service bus) ???
Can the part of the flash containing the config be copied to an SD card and then reflashed after the update process is complete?
@ networkfusion - I’m sorry, didn’t see the file part. You can find the config.hex and firmware.hex files in our SDK, C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Firmwares\G400 for example. I believe the SSL seed is saved in the config.
Persisting the configuration settings between IFU calls (and potentially even firmware update) is something we are looking into but have nothing at this time.
If you have and SD card or an extra Flash chip connected, you could store all the information there.
On startup you compare it, and if different write it back to the device flash and reboot once more.
This is how I do it with the Mac address, and it works really fine:
var myMac = GenerateUniqueMacAddr(uniqueId);
if (!ByteArrayEquals(eth.PhysicalAddress, myMac))
//update the Mac Address
eth.PhysicalAddress = myMac;
//Hard Reboot the device so the newly Updated MAC is taking into consideration.
PowerState.RebootDevice(false);
instead of generating an MAC by the serial number I have stored on SD, you could read your MAC from SD or external flash.
@ networkfusion - While we did not change IFU to persist the SSL seed or other configuration, the latest pre-release SDK has methods to read and write the configuration. Combined with an SD card or other external storage, you could persist the SSL seed.
Since the configuration is loaded into RAM before it is written back to flash, is there any need to persist it to an SD card beforehand or could I just do something like:
using GHI.Processor;
InFieldUpdate.Load(InFieldUpdate.Types.Configuration, Configuration.Read(), Configuration.Size);
@ networkfusion - You can’t use the data returned from Configuration in the InFieldUpdate class. You have to persist it somewhere externally since the board resets after IFU flashes the new data.
