During the software update process, mixing up NetMF v4.2 and NetMF v4.3 binaries is a bad thing.
At that point, because there is no direct access to the controller PCB in the field, a costly repair can be generated.
I’ll be living with this problem because a legacy board will not run NetMF v4.3 due to its more rigorous pin reservations.
The legacy boards will be around a long time.
So, I’m looking for a way to know what version of binary is coming in by checking the s-records.
My initial observation is that the eighth character of the first s-record is different between the NetMF versions. I’m thinking this could be the base address, and it could be a fixed difference between the versions.
Has anyone on the forum had this type of problem, how did you deal with it, and can I rely on the fixed difference outlined above?
