Access Modifiers - C# Reference | Microsoft Docs
interface - C# Reference | Microsoft Docs
I am going to try to see if I can provide some insight based on my understanding, I am making some assumptions here. You mention interface having an affect on your internal constructor.
So here is my unsolicited input:
Interface - An interface has no bearing on how a class implements its constructor(s), it is just a contract for what the class should posses, that is, members, events, and/or the methods, not the constructors; this is different than an abstract class.
Internal - This is a modifier that sets the visibility of a class in an assembly to be instantiable only within that assembly
public delegate void SampleGpioPinValueChangedEventHandler(object sender, EventArgs e);
//Sample interface
    public interface ISample
        public string Property { get; }
        public void Method();
        public event SampleGpioPinValueChangedEventHandler SampleEvent; //Must be a delegate
//valid - default constructor (public)
 public class SampleClass : ISample
        public string Property => throw new NotImplementedException();
//Valid - internal constructor, class can only be instantiated within the same assembly
internal SampleClass(){
//Valid - private constructor normally used when when creating a singleton
private SampleClass(){}
What you submitted on Gitub  is not a bug
public sealed class GpioPinValueChangedEventArgs : EventArgs
    public GpioPinEdge Edge { get; }
    public DateTime Timestamp { get; }
    internal GpioPinValueChangedEventArgs(GpioPinEdge edge, DateTime timestamp)
      this.Edge = edge;
      this.Timestamp = timestamp;
Here, you are inheriting from a class and not an interface, in your case EventArgs. Inheritance is a topic too large to discuss in a forum.
Inheritance in C# | Microsoft Docs
Edited: The reason you had to set the constructor of your  GpioPinValueChangedEventArgs class to public is because the EventArgs  class has public constructor(s).
//EventArgs definition, not actual implementation
[ComVisible(true)]
    public class EventArgs
        public EventArgs();
