I’m working on a project that need to send a image from a pc to the chipworkx, the project its implemented throught WCF on MF 4.1 and the ChipworkX works like a client on this process.
I have tried to convert the image to string base 64 and it work, but the response time its excessive (about a minute). I have thought on use DataContract Serialization but i’m not sure if that would work, hope you can give me some clues and ideas
You say the response time is excessive, but you have not explained what this means. Do you mean the time it takes to convert to string base 64, or the time it takes to send the image to the chipworkx?
What method are you using to transfer the image to the chipworkx? Ethernet or serial?
Have you tried to determine exactly what step of the process is the bottleneck?
Sorry for the lack of details, but i’ll try to be more precise,
About the response time i was talking about the time it takes to deserialize the data from base64 it takes about 40 seconds to 1,2 minutes. And this process its the bottleneck, cause the transfer from the PC works fine.
I’m using ethernet, to be more detailed, im using dpws to do the process.
Actually DataContracts and DPWS are part of WCF, dpws its a set of minimal requirements that let devices detect other dpws enabled devices over a network and consume their web service, for the specific case of ChipworkX it has support for it.
Base64 is generally used to convert bytes to strings. So the 256 base byte is converted to some 64 base chars (which are sent as bytes over ethernet). So you actually increase the amount of data transfered. Also, the conversion between bases adds some extra time.
Thanks for the replies, i have made some test without serialize and it seems to work just fine, but now i have another issue, i’m using ws2007http binding and it seems to have a limited buffer size, it’s there a way to increase the size???
As you can see the reader quotas are fine, but this is on server side. This is the code that i’m deploying on the chipworkx
public class Program : Microsoft.SPOT.Application
//Windows
private Window mainWindow;
private Image imageView;
Program myApplication = new Program();
Window mainWindow = myApplication.CreateWindow();
// Create the object that configures the GPIO pins to buttons.
GPIOButtonInputProvider inputProvider = new GPIOButtonInputProvider(null);
// Start the application
myApplication.Run(mainWindow);
public void GetImage(ClientApp test)
NetworkInterface networkInterface;
networkInterface = NetworkInterface.GetAllNetworkInterfaces()[0];
if (networkInterface.IPAddress != "0.0.0.0") break;
Thread.Sleep(1000);
test.Run();
Debug.Print(test.response.GetEmployeeInfoResult.photo.ToString());
Deserialize(test.response.GetEmployeeInfoResult.photo);
public Window CreateWindow()
// Create a window object and set its size to the
// size of the display.
mainWindow = new Window();
mainWindow.Height = SystemMetrics.ScreenHeight;
mainWindow.Width = SystemMetrics.ScreenWidth;
mainWindow.Background = new SolidColorBrush(Color.Black);
imageView = new Image();
imageView.HorizontalAlignment = Microsoft.SPOT.Presentation.HorizontalAlignment.Center;
imageView.VerticalAlignment = Microsoft.SPOT.Presentation.VerticalAlignment.Center;
mainWindow.Child = imageView;
// Connect the button handler to all of the buttons.
mainWindow.AddHandler(Buttons.ButtonUpEvent, new RoutedEventHandler(OnButtonUp), false);
// Set the window visibility to visible.
mainWindow.Visibility = Visibility.Visible;
// Attach the button focus to the window.
Buttons.Focus(mainWindow);
return mainWindow;
private void OnButtonUp(object sender, RoutedEventArgs evt)
ClientApp test = new ClientApp();
GetImage(test);
public void Deserialize(byte[] byteArray)
if (byteArray.Length > 0)
mainWindow.Background = new SolidColorBrush(Colors.Black);
imageView.Bitmap = new Bitmap(byteArray, Bitmap.BitmapImageType.Jpeg);
imageView.Invalidate();
public class ClientApp
IInfoServiceClientProxy m_clientProxy;
public GetEmployeeInfoResponse response;
private bool Discover(IInfoServiceClientProxy proxy)
DpwsServiceTypes typeProbes = new DpwsServiceTypes();
typeProbes.Add(new DpwsServiceType("IInfoService", "http://192.168.1.101:8090/InfoService"));
DpwsServiceDescriptions descriptions = proxy.DiscoveryClient.Probe(typeProbes, 1, 2000);
if (descriptions.Count > 0)
proxy.EndpointAddress = descriptions[0].Endpoint.Address.AbsoluteUri;
return true;
return false;
public void Run()
Uri remoteEp = new Uri("http://192.168.1.101:8090/InfoService");
HttpTransportBindingConfig tbc = new HttpTransportBindingConfig(remoteEp);
HttpTransportBindingElement el = new HttpTransportBindingElement(tbc);
ArrayList al = new ArrayList();
WS2007HttpBinding binding = new WS2007HttpBinding(tbc, al);
binding.Elements.GetBindingProperty("maxBufferPoolSize");
ProtocolVersion ver = new ProtocolVersion11();
m_clientProxy = new IInfoServiceClientProxy(binding, ver);
m_clientProxy.IgnoreRequestFromThisIP = false;
if (!Discover(m_clientProxy))
Debug.Print("Error");
m_clientProxy.EndpointAddress = "http://192.168.1.101:8090/InfoService";
GetEmployeeInfo req = new GetEmployeeInfo();
req.message = "death.jpg";
try
response = m_clientProxy.GetEmployeeInfo(req);
catch (WsFaultException ex)
Debug.Print("DPWS Fault: " + ex.Message);
finally
m_clientProxy.Dispose();
