IFU problems when downloading file
Hey all,
I’m trying to do an IFU, basically using the example code from the site. I’m trying to pull the files from a web server. For reference, my app TCA file is 587KB. Here’s what I have:
 public void updateFw(string url, string fwUrl)
            Debug.WriteLine("App " + url);
            Debug.WriteLine("FW " + fwUrl);
                var qspiController = StorageController.FromName(SC20260.StorageController.QuadSpi);
                var indicatorPin = GpioController.GetDefault().OpenPin(SC20260.GpioPin.PB5);
                var appKey = new byte[] { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; // your key, assumming they are all zero as example.
                var updater = new InFieldUpdate(qspiController)
                    ActivityPin = indicatorPin
                var dataChunk = new byte[1 * 1024]; // must be multiple of 1K
                var dataChunkFW = new byte[1 * 1024]; // must be multiple of 1K
//Application
                var req = HttpWebRequest.Create(url) as HttpWebRequest;
                    req.KeepAlive = true;
                    req.ReadWriteTimeout = 2000;
                    var res = req.GetResponse() as HttpWebResponse;
                // Buffer application
                var idxApp = 0;
                var appStream = res.GetResponseStream();
                while (idxApp < appStream.Length)
                    var count = appStream.Read(dataChunk, 0, dataChunk.Length);
                    idxApp += updater.LoadApplicationChunk(dataChunk, 0, count);
//Firmware
                var reqFw = HttpWebRequest.Create(fwUrl) as HttpWebRequest;
                reqFw.KeepAlive = true;
                reqFw.ReadWriteTimeout = 2000;
                var resFw = reqFw.GetResponse() as HttpWebResponse;
                var steamFW = resFw.GetResponseStream();
                // Buffer firmware
                var idxFirmware = 0;
                while (idxFirmware < steamFW.Length)
                    var count = steamFW.Read(dataChunk, 0, dataChunk.Length);
                    idxFirmware += updater.LoadFirmwareChunk(dataChunk, 0, count);
                //Load key
                updater.LoadApplicationKey(appKey);
                Debug.WriteLine("Verifying application.... ");
                Debug.WriteLine("Application version: " + updater.VerifyApplication());
                Debug.WriteLine("Verify firmware.... ");
                Debug.WriteLine("Firmware version: " + updater.VerifyFirmware());
                // Flashing
                updater.FlashAndReset();
I have an IP address and confirmed network connection. This fails with:
App http://loledvirtual.com/conduit/conduitx4/App.tca
FW http://files.ghielectronics.com/downloads/TinyCLR/Firmwares/SITCore/SITCore-SC20-Firmware-v2.1.0.6500.ghi
    #### Exception System.ArgumentException - 0xfd000000 (1) ####
    #### Message:
    #### GHIElectronics.TinyCLR.Update.InFieldUpdate::NativeAuthenticateApplication [IP: 0000] ####
    #### GHIElectronics.TinyCLR.Update.InFieldUpdate::VerifyApplication [IP: 0016] ####
    #### Conduit.FirmwareUpdater::OnFirmwareUpdate [IP: 000d] ####
    #### Conduit.UDPManager::checkForData [IP: 00e4] ####
    #### Conduit.Program::Main [IP: 0310] ####
Exception thrown: 'System.ArgumentException' in GHIElectronics.TinyCLR.Update.dll
Exception was thrown: System.ArgumentException
The thread '<No Name>' (0x5) has exited with code 0 (0x0).
Not really sure what the proper way of handling this is, any advice appreciated.
make sure count is always multiple of 1K.
Read from network stream not always 1K. You need to wait enough 1K before do
This can also be related to the version number you entered in tinyclr config when making your tca file.
Make sure the version number is in the same format: x.x.x.x otherwise you’ll also get this exception.
Is there any concern that the app file size won’t be multiple of 1024, or is the size padded to ensure it’s not a problem?
It’s my understanding that the file will always be in multiples of 1024.
