I’ve done a fair bit with I2C before however not before with Gadgeteer … basically I have a lovely sensor that is not talking to my mainboard.
I just need a sanity check in case I missing something
Module building
It’s I2C so I’ve done type “I”, of course
As with type I, pin 3 is GPIO and not shared where Pin 8 (SDA - data) is shared as is Pin 9 (SCL - clock)
Also included “Gadgeteer.DaisyLink” assembly reference for 2.4.2 builds.
Electronics
Should be all OK and I’ve check with my multi-meter on my breadboard … see picture.
VCC is getting 3.3V, Ground is grounded Chip selected is tied high for the right address.
Both SDA and SCL are pulled high with resistors.
Also I’ve continuity from the breakout board pin all the way to the Gadgeteer pin.
Code
Originally tried to have all the code in the module, however as it was not working brought it into the program for quicker testing. I guess that makes the module part redundant
GT.Socket socket = GT.Socket.GetSocket(
2, // socked connected
true, // throw if socket invalid
null, // not part of a module
null); // socket label
ushort sensorAddress = 0x1D;
i2c = new GTI.I2CBus(
socket, // socket
sensorAddress, // ADXL354 device ID
100, // 100 Hz
null); // not part of a module
byte[] writebuff = new byte[1]; // write buffer
byte[] readbuff = new byte[1]; // read buffer
writebuff[0] = 0; // want register 0 which is device ID
int bytesTransfered = i2c.WriteRead(
writebuff, // write register I want
readbuff, // read data containing device ID
1000);
Ordinarily did try without the pull-ups however no joy.
Haha, I thought you needed that Daisylink resource so it included the I2C. I guess it wasn’t doing any harm, thank you for the info!
Good eye too! Yes 100 kHz not 100Hz!
The SDO (alternative address) is high so the address of the ADXL should be 0x1D (page 18 of above link). Also got some handy code from LoveElectronics showing it should be that.
My mainboard is the Argon R1, again from LoveElectronics.
Cheers GMod, interesting that the WriteRead and Write then Read behave a little differently. This is definitely worth a try, thanks for the support!!!
Cheers Architect, I see that’s the address when the SDO is low … I’ll give it a go all the same just to be sure! Worth a check
The mainboard is the ArgonR1. What I have is a module that then exposes the Gadgeteer pins so you can wire them into a breadboard. Handy! All the power and ground comes from the mainboard. I’ve double checked with a multi-meter and all the power (using 3.3V) are good as is the ground.
Very much appreciated all the support from everyone!
May be that your board does not support GTI = Gadgeteer.Interfaces. I am not shure but I think that this is part of the GHI premium software boards. May be that you have to use software I2C.
I think that is the default address plus the extra write bit set low.
Perhaps my misunderstanding however, I thought with the .NET MF code you would give the normal address to the I2CBus constructor and then it would manage the extra read/write bit flag?
socket, // socket
100, // 100 KHz
int bytesWritten = i2c.Write(writebuff, timeOut); // request device id on write
int bytesRead = i2c.Read(readbuff, timeOut); // get the device id on read
“Ensuring that CS has been connected to VCC, and SDO has also been tied to VCC. Not connecting CS to VCC will mean I2C is not enabled, and the device will not respond. Not connecting SDO to VCC will mean the ADXL345 does not know which address it is at, and will not respond. Check all your connections and try again.”
First thing, don’t panic. Unlikely to have borked the entire board just uploading code and it failed to do so.
I would boot into bootloader mode, and erase the firmware and reapply it. I don’t know the R1 so I can’t tell you how to do that, but that’s my first tip, reapply the firmware from scratch should get you back up and ping-able from mfdeploy.
Timely thread as I was learning a bit about I2C interfaces by coding up a TMP100 chip, this thread helped me get the changing of functions via writing to the register, Thanks.
Thanks Brett, great to wake up and to find it might be OK … my wallet and I are much happier!
I’ll contact Love Electronics and see what they recommend!
