Hi again, I have only socket 1 (HI) on the Cerb left, and want to communication with a Cobra II - was planning to try I2C but are having problems finding examples for interboard communication using I2C.
Other people have asked this forum for assistance on this, but no-one really got it solved.
Some people have indicated that NETMF does not support being a slave on the i2c bus, if that is true, what to do then?
basically because you have to write thelot. The UART hardware helps you a huge amount, probably more than you realize. Perhaps you’d be better off taking the software I2C and extend that to cover the slave capability?
Personally, I’d ask are you using all the UARTs themselves or just the pins around them ? If you haven’t used them all, figure out how to move your connected devices around to free one up.
