Hi
I’ve got an I2C component and I need to communicate with it.
The frame provided by the constructor says this:
To write data, here is the sequence
Start / Adresse 0x57 / Write / ack / 0x06 / Ack … / Stop
What do I need do make it work ?
I guess I have to create a Write Transaction but what do I have to put in the buffer to be
provided to the write transaction ?
Do I only have to give something like that :
byte[] data = new byte[4]{0x06, OneData, TwoData, ThreeData};
or do I need to do something else ?
thanks a lot
We handle everything internally, you only need to send your data…skip ack/nack/stop/start…etc.
Ok
So If I only need to send
0x06/ack/0x33/ack/0x33/stop
I only need to create bye[] with 3 data as 6,0x33 and 0x33 ?
Is that correct ?
Have a look at my driver for the Devantech LCD : (link removed)
It may help you. Also, you should know in which register to write and what data you have to send. What is your component ?
Hi
Here is the PDF document to write and read my component…
here is the link to get the small documentation…
Jusqu’à 28 Méga, 10Go d’espace disque, WiFi-MiMo, Ligne téléphonique, Appels illimités vers 70 destinations, 250 chaînes de télévision, Vidéo à la Demande
Can you tell me if what I do is ok.
For writing sensor heat, I do
One transaction will only WriteTransaction with byte[4] ==> 0x06,0xF0,0xF0,0xF0…
After doing this, only the first value seems to be send…
For reading the value of the resistance, I do this:
WriteTransaction with buffer byte[1] = 0x00
ReadTransaction with buffer byte[6];
