@ Skewworks -
Here is the output:
Found debugger!
Create TS.
Loading start at a0e69394, end a0e98828
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Resolving.
GC: 1msec 284784 bytes used, 7054884 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 7054884 bytes
Type 17 (ASSEMBLY ): 21180 bytes
Type 1E (BINARY_BLOB_HEAD ): 263508 bytes
GC: performing heap compaction…
Ready.
Cannot find any entrypoint!
Done.
Waiting for debug commands…
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘Microsoft.SPOT.Debugger.CorDebug.14.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
The program ‘[20] Micro Framework application: Managed’ has exited with code 0 (0x0).
