@ Architect -
Sorry for the delay but unexpected things I had to do.
The project was run on a Spider using a T35 LCD.
This is a sample that shows my main issue. Forget the displayed bitmap clipping and position.
My main question would be about the black rectangle (Bitmap b = new Bitmap(200, 180) behind the bitmap rotated. I have not been able to change the black to a background color.
I do not understand why it is black or how to change/hide the background color.
The reason for asking the proper way to display a rotated bitmap someplace on the LCD (without it having the black background).
This sample code will show the black rectangle
image2.gif is the same as the bitmap I used for rotation.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using MSPM = Microsoft.SPOT.Presentation.Media;
using GHI.Premium.System;
namespace GadgeteerTest1
public partial class Program
//private DrawingContext dc;
Bitmap bmpCopy;
Bitmap bmpMyBitmap;
display_T35.SimpleGraphics.BackgroundColor = Colors.White;
display_T35.SimpleGraphics.Clear();
button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
//Non transparent bitmap with blue background and black lines/text for testing
bmpMyBitmap = Resources.GetBitmap(Resources.BitmapResources.image2); //Size is 150X150
Debug.Print("Program Started. Press button");
//Used in case I trash my spider on last deploy (So app does not hang the Spider)
void button_ButtonPressed(Button sender, Button.ButtonState state)
Debug.Print("Button was pressed");
//Test for now .. Need to find value of bitmap diagonal
bmpCopy = new Bitmap(bmpMyBitmap.Width, bmpMyBitmap.Height);
//Copy the bitmap. Position test to view our blue background bitmap
bmpCopy.DrawImage(0, 0, bmpMyBitmap, 0, 0, bmpMyBitmap.Width, bmpMyBitmap.Height);
bmpCopy.MakeTransparent(Microsoft.SPOT.Presentation.Media.Color.White);
//This bitmap appears on the screen as the black rectangle
Bitmap b = new Bitmap(200, 180); //No particular reason choosing this size
//Be VERY careful of bitmap size/placement - The following code trashes Spider.. See note below code
//b.RotateImage(45, 80, 80, bmpCopy, 0, 0, bmpCopy.Width, bmpCopy.Height, Bitmap.OpacityTransparent);
//display_T35.SimpleGraphics.DisplayImage(b, 60, 60);
//This (sort of works) except for black background
//Assume I need a clipping rectangle?
b.RotateImage(45, 0, 0, bmpCopy, 0, 0, bmpCopy.Width, bmpCopy.Height, Bitmap.OpacityOpaque);
display_T35.SimpleGraphics.DisplayImage(b, 20, 20);
Trashed - This has caused firmware trash in the past
LCD shows (similar)
ABORT Data
Build Date:
Aug 15 2013
11:41:08
cps= 0x8000007f
pc= 0x00025640
lr= 0x000e09ce
sp= 0x4000f60c
Thank you…
