I cant see Fez panda features at the microfreamwork options
Help me for this situation. I cant see Fez Panda Applications… Only 4 options avaliable here.
have you installed the 4.1 SDK?
no. i dont install it @ Mike -
@ aslanmax - well do it! :slight_smile:
the panda requires the 4.1 SDK . check the bottom of the support page.
first- i have to install 4.1 after that install 4.2 and 4??@ Mike -
@ aslanmax - you can install the 4.1 SDK after the 4.2. that’s all you need.
thx my friend!!!@ Mike -
Can i programming fez panda 2 at VS2012?@ Mike -
@ aslanmax - if you install .NET Micro Framework SDK 4.3 (RTM) then you should be able to program for 4.1.
https://www.ghielectronics.com/support/.net-micro-framework
