I’ve seen this using a 6pF cap instead of the correct 12pF one.
My boards don’t have any capacitors as I use the MAX1338 and it doesn’t need them but the Hydra processor needs them. As you crystal is 12.5pF, I would check, as Gus suggested, the capacitors on the board are correct.
That crystal you are using requires 12.5pF capacitors. The Hydra board comes populated with 27pF capacitors for C21 and C22, so you need to change them. Since there aren’t actually any 12.5pF caps, I used 12pF (CL10C120JB8NNNC).
