I have recently updated to the newest versions on my PC, no problems there and I’ve update my FEZ Spider which is working, love the new config it works a treat.
However, I can’t update my Hydra. The config recognizes it, but it fails to ping. There are no errors in the device manager it is recognized.
I’ve had a look on the forum but not found anything - am I missing a step?
I have so far found the Hydra to be the best board so I’m keen to get it up and running again.
Can you add one from before you try to update the firmware (should show Hydra’s name in the field next to USB) and the details from the other two tabs of the driver.
(faint memory here: wasn’t there some reason about NOT using winUSB driver on Hydra?)
I recently re-installed everything so I was on the new GHI software for Visual Studio. I have only updated the Spider board I have, I have not been able to do this one at all since re-installing everything - actually it was working fine before the new install so the driver maybe, has this changed?
I have added the extra screen shots though I cannot see any tab relating to the driver.
@ shapingstuff - Try to place the board into TinyBooter mode to see if the Hydra will ping in MFDeploy. To do this you will need to ground pin 9 (easiest way is with an extender board) and hold it for a second or two while rebooting the board.
If you can get the board to ping, use MFDeploy to reload the firmware but make sure it is the non Ethernet firmware or the board will appear to be locked up as you are describing now.
