I have project i wrote for simulate fast protocol using Hydra. I am starting with .Net and after that going to RLP and run in C code.
when I started this project i saw that Hydra had a short delay from time to time and i disabled AIC interrupts (*AT91C_AIC_IDCR = 0xffffff;).
It worked fine till last week, when i upgraded my environment to 4.3 (it was 4.2 till now).
Using the same code in manage(.net) and unmanage(RLP) i see short delays in hydra.
i am using same physical devices - led, usb serial, etherenet and button, but for some reason it looks like in 4.3 the framework enables interrupts that wasn’t there in 4.2
Anyone have idea how can i disable new interrupts? maybe its other issue that came in 4.3…
I really dont know what to do with it…
I can try it. the only different i can see between 4.2 and 4,3 is the ethernet device. in 4.2 i didnt add it in schematic. in 4.3 i have it like i have all other devices.
Do you know if Ethernet device register to interrupts? if yes - which?
@ shm3 - It’s pin 3 on the socket, but it is required for Ethernet to function so disabling it really isn’t possible if you use Ethernet in your solution. 4.2 also had the same interrupt enabled when using Ethernet though.
