I have some trouble deploying my project to hydra. The project is running in VS2012 and I can deploy and debug everything to the hydra board by pressing F5.
When I make a power cycle or reset of the board the application is not running automatically.
What is to do to start the application after reset by the bootloader without any pc?
I tried to use release setting in VS2012 with the same result. I can deploy everything and after reset, the application is not starting without pc.
I created a hex file with the Deployment tool and deployed it to the board with the same result. The application will be deployed to Base Address 0x00294000.
After the reset the T43 display shows the TinyBooter sceen and stops with the message:
The problem was a damaged flat cable connector at a extender modul. Pin 9 was shortet to GND in the connector! After I changed the flat cable the board is booting my application now.
Hard to believe, but this little cable caused all my problems…
