Hello Folks,
sorry to annoy, but I must report an error with firmware 4.3.7.9 of the Hydra+ - it, sadly, also occurred on 4.3.7.7. My circuit consists of an ENC28 module added to port 3, which is connected to a router.
When running the program, I get the following output from the Network Interface list - it looks as if my Gadgeteer has three network ports:
NetworkAvailabilityChanged: True
IF : 6
IP : 0.0.0.0
Mask : 0.0.0.0
Gateway : 0.0.0.0
DCHP Enable : True
IF : 6
IP : 192.168.0.100
Mask : 255.255.255.0
Gateway : 192.168.0.1
DCHP Enable : True
DNS : 208.67.222.222
IF : 71
IP : 0.0.0.0
Mask : 0.0.0.0
Gateway : 0.0.0.0
DCHP Enable : True
While this may be but a cosmetic problem, the real crash occurs here:
private void StartServerInternal()
try
Socket clientSocket = mySocket.Accept();
//Process connection
Debug.Print("Success");
catch (Exception e)
Debug.Print("Exception E33");
Even though the Hydra was provided with an IP adress from the router, invoking Accept() still yields a 10050 error as per below:
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (6) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::poll [IP: 0000] ####
#### System.Net.Sockets.Socket::Poll [IP: 0011] ####
#### System.Net.Sockets.Socket::Accept [IP: 0017] ####
#### NMGCustomProtocol.Program::StartServerInternal [IP: 000c] ####
#### SocketException ErrorCode = 10050
Eine Ausnahme (erste Chance) des Typs "System.Net.Sockets.SocketException" ist in Microsoft.SPOT.Net.dll aufgetreten.
This is my full code:
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using System.Net.Sockets;
using System.Net;
namespace NMGCustomProtocol
public partial class Program
Object myLock;
NetworkInterface myInterface;
System.Net.Sockets.Socket mySocket;
myLock = new Object();
var item = NetworkInterface.GetAllNetworkInterfaces();
var myMac = ethernetENC28.NetworkInterface.PhysicalAddress;
Thread.Sleep(5000); //Notwenig, aber kA wieso
ethernetENC28.UseDHCP();
NetworkChange.NetworkAvailabilityChanged += NetworkChange_NetworkAvailabilityChanged;
NetworkChange.NetworkAddressChanged += NetworkChange_NetworkAddressChanged;
ethernetENC28.NetworkUp += ethernetENC28_NetworkUp;
ethernetENC28.NetworkDown += ethernetENC28_NetworkDown;
ethernetENC28.NetworkInterface.Open();
ethernetENC28.UseThisNetworkInterface();
while (!ethernetENC28.IsNetworkUp)
Thread.Sleep(250);
Debug.Print("ZZZ");
timer.Tick +=<tab><tab>
timer.Start();
timer.Tick += timer_Tick;
timer.Start();
mySocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
IPEndPoint localEndPoint = new IPEndPoint(IPAddress.Any, 23);
mySocket.Bind(localEndPoint);
mySocket.Listen(2);
new Thread(StartServerInternal).Start();
// Debug.Print("Lebe noch!" + ethernetENC28.NetworkInterface.IPAddress);
private void NetworkChange_NetworkAddressChanged(object sender, EventArgs e)
lock (myLock)
foreach (var item in NetworkInterface.GetAllNetworkInterfaces())
Debug.Print("IF-ID: " + item.NetworkInterfaceType);
Debug.Print("IP: " + item.IPAddress);
private void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
Debug.Print("NetworkAvailabilityChanged: " + e.IsAvailable);
if (e.IsAvailable)
Debug.Print("IF : " + item.NetworkInterfaceType);
Debug.Print("IP : " + item.IPAddress);
Debug.Print("Mask : " + item.SubnetMask);
Debug.Print("Gateway : " + item.GatewayAddress);
Debug.Print("DCHP Enable : " + item.IsDhcpEnabled);
foreach (var dns in item.DnsAddresses)
Debug.Print("DNS : " + dns);
if (item.IPAddress != "0.0.0.0")
myInterface = item;
try
catch (Exception e)
private void ethernetENC28_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("ENC-Verbindung aktiviert. IP-Adresse: " + ethernetENC28.NetworkInterface.IPAddress);
void ethernetENC28_NetworkDown(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("ENC-Verbindung verloren. Kabelzustand: " + ethernetENC28.NetworkInterface.CableConnected);
To me, it looks as if the ethernetENC28 interface does never get the IP adress from the router, which is, instead, assigned to the “phantom” interface.
Anyone have any ideas for me?
