The snippet below works fine until the very last line where I tried to read the StatusCode.
It threw exception.
I was able to read the response content correctly, even StatusDescription is read correctly.
The actual returned http status from the server is 200.
From the internal code, this seems to suggest it’s not implemented?
using (var res = req.GetResponse() as HttpWebResponse)
using (var stream = res.GetResponseStream())
do
read = stream.Read(result, 0, result.Length);
total += read;
System.Diagnostics.Debug.WriteLine("read : " + read);
System.Diagnostics.Debug.WriteLine("total : " + total);
var page = new String(System.Text.Encoding.UTF8.
GetChars(result, 0, read));
System.Diagnostics.Debug.WriteLine("Response : " + page);
while (read != 0);
Debug.WriteLine("status desc = " + res.StatusDescription);
Debug.WriteLine("status code = " + res.StatusCode);
Here is the exeception:
DoTestHttps
read : 54
total : 54
Response : {“flag”: “flag{1b17b7465163a52dbd6c10175f84d273}”}
read : 0
total : 54
Response :
status desc = OK
#### Exception System.Exception - CLR_E_UNSUPPORTED_INSTRUCTION (1) ####
#### Message:
#### TinyCLRApplication.Program::DoTestHttps [IP: 0134] ####
#### TinyCLRApplication.Program::Main [IP: 0128] ####
Exception thrown: ‘System.Exception’ in TinyCLRApplication.exe
