I using DownloadFile() method from Pyxis2 to download HEX files from HTTP server but something do not work ok.
Here is code:
public static int DownloadFile(string url, string file)
return DownloadFile(url, file);
public static int DownloadFile(string url, string file, int bufferSize = 1024)
try
// Ensure Directory
if (!Directory.Exists(Path.GetDirectoryName(file)))
Directory.CreateDirectory(Path.GetDirectoryName(file));
// Perpare for file
if (File.Exists(file))
File.Delete(file);
VolumeInfo sdvolumeinfo = new VolumeInfo(Module.storage);
sdvolumeinfo.FlushAll();
FileStream FS = new FileStream(file, FileMode.CreateNew, FileAccess.Write);
byte[] b = new byte[bufferSize];
HttpWebRequest request = HttpWebRequest.Create(url) as HttpWebRequest;
request.KeepAlive = false;
WebResponse resp = request.GetResponse();
// Get the network response stream to read the page data.
if (resp != null)
Stream respStream = resp.GetResponseStream();
int bytesRead = 0;
Decoder UTF8decoder = System.Text.Encoding.UTF8.GetDecoder();
int totalRead = 0;
// allow 5 seconds for reading the stream
respStream.ReadTimeout = 5000;
// If we know the content length, read exactly that amount of
// data; otherwise, read until there is nothing left to read.
if (resp.ContentLength != -1)
for (int dataRem = (int)resp.ContentLength; dataRem > 0; )
//Thread.Sleep(50);
bytesRead = respStream.Read(b, 0, (dataRem > b.Length) ? b.Length : dataRem);
FS.Write(b, 0, bytesRead);
if (bytesRead == 0)
throw new Exception("Data less than expected");
totalRead += bytesRead;
dataRem -= bytesRead;
// Attempt to read chunks
b = new byte[1024];
string strOut = string.Empty;
Thread.Sleep(500);
if (b.Length > respStream.Length)
b = new byte[respStream.Length];
bytesRead = respStream.Read(b, 0, b.Length);
if (bytesRead == 0)
break;
// Close the response stream. For Keep-Alive streams, the
// stream will remain open and will be pushed into the unused
// stream list.
resp.Close();
request.Dispose();
FS.Close();
return totalRead;
return 0;
catch (Exception e)
return 0;
Module.storage=“SD”;
for example I call this:
Debug.GC(true);
Module.WriteDebugLog("Update.DownloadUpdates() - File: app.hex Size: " + Network.DownloadFile("http://www.domain.com/updates/app.hex", UpdateFolder + "app.hex", 5120));
Debug.GC(true);
Module.WriteDebugLog("Update.DownloadUpdates() - File: bootloader.hex Size: " + Network.DownloadFile("http://www.domain.com/updates/bootloader.hex", UpdateFolder + "bootloader.hex", 5120));
Debug.GC(true);
Module.WriteDebugLog("Update.DownloadUpdates() - File: CLR.HEX Size: " + Network.DownloadFile("http://www.domain.com/updates/CLR.HEX", UpdateFolder + "CLR.HEX", 5120));
Debug.GC(true);
Module.WriteDebugLog("Update.DownloadUpdates() - File: CLR2.HEX Size: " + Network.DownloadFile("http://www.domain.com/updates/CLR2.HEX", UpdateFolder + "CLR2.HEX", 5120));
Debug.GC(true);
Module.WriteDebugLog("Update.DownloadUpdates() - File: Config.HEX Size: " + Network.DownloadFile("http://www.domain.com/updates/Config.HEX", UpdateFolder + "Config.HEX", 5120));
Debug.GC(true);
Module.WriteDebugLog("Update.DownloadUpdates() - Files Downloading Completed");
UpdateFolder = @ “\SD\update”;
Error:
GC: 26msec 278256 bytes used, 9617208 bytes available
Type 0F (STRING ): 5928 bytes
Type 11 (CLASS ): 17400 bytes
Type 12 (VALUETYPE ): 684 bytes
Type 13 (SZARRAY ): 37848 bytes
Type 15 (FREEBLOCK ): 9617208 bytes
Type 16 (CACHEDBLOCK ): 3912 bytes
Type 17 (ASSEMBLY ): 31836 bytes
Type 18 (WEAKCLASS ): 144 bytes
Type 19 (REFLECTION ): 192 bytes
Type 1B (DELEGATE_HEAD ): 1656 bytes
Type 1C (DELEGATELIST_HEAD ): 180 bytes
Type 1D (OBJECT_TO_EVENT ): 696 bytes
Type 1E (BINARY_BLOB_HEAD ): 167256 bytes
Type 1F (THREAD ): 2688 bytes
Type 20 (SUBTHREAD ): 336 bytes
Type 21 (STACK_FRAME ): 2712 bytes
Type 22 (TIMER_HEAD ): 144 bytes
Type 27 (FINALIZER_HEAD ): 816 bytes
Type 31 (IO_PORT ): 684 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 3072 bytes
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (16) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::recv [IP: 0000] ####
#### System.Net.Sockets.Socket::Receive [IP: 0018] ####
#### System.Net.Sockets.NetworkStream::Read [IP: 0062] ####
#### System.Net.InputNetworkStreamWrapper::ReadInternal [IP: 00d7] ####
#### System.Net.InputNetworkStreamWrapper::Read [IP: 000d] ####
#### PEPP.Network::DownloadFile [IP: 00b4] ####
#### PEPP.Update::DownloadUpdates [IP: 01ac] ####
#### PEPP.Update::UpdateThread [IP: 0068] ####
#### SocketException ErrorCode = 10060
A first chance exception of type 'System.Net.Sockets.SocketException' occurred in Microsoft.SPOT.Net.dll
11/01/2011 06:57:01: Update.DownloadUpdates() - File: app.hex Size: 0
GC: 11msec 274092 bytes used, 9621372 bytes available
Type 0F (STRING ): 6936 bytes
Type 11 (CLASS ): 18720 bytes
Type 13 (SZARRAY ): 29856 bytes
Type 15 (FREEBLOCK ): 9621372 bytes
Type 16 (CACHEDBLOCK ): 240 bytes
Type 1E (BINARY_BLOB_HEAD ): 171852 bytes
Type 1F (THREAD ): 3072 bytes
Type 20 (SUBTHREAD ): 384 bytes
Type 27 (FINALIZER_HEAD ): 960 bytes
#### Message:
11/01/2011 06:57:17: Update.DownloadUpdates() - File: bootloader.hex Size: 0
GC: 10msec 291288 bytes used, 9604176 bytes available
Type 0F (STRING ): 6912 bytes
Type 11 (CLASS ): 18360 bytes
Type 13 (SZARRAY ): 47604 bytes
Type 15 (FREEBLOCK ): 9604176 bytes
Type 16 (CACHEDBLOCK ): 96 bytes
Type 27 (FINALIZER_HEAD ): 936 bytes
#### Message:
11/01/2011 06:57:29: Update.DownloadUpdates() - File: CLR.HEX Size: 0
GC: 10msec 450564 bytes used, 9444900 bytes available
Type 0F (STRING ): 6864 bytes
Type 11 (CLASS ): 18384 bytes
Type 13 (SZARRAY ): 53412 bytes
Type 15 (FREEBLOCK ): 9444900 bytes
Type 1E (BINARY_BLOB_HEAD ): 325548 bytes
Type 21 (STACK_FRAME ): 2508 bytes
#### Message:
11/01/2011 06:57:44: Update.DownloadUpdates() - File: CLR2.HEX Size: 0
GC: 10msec 436716 bytes used, 9458748 bytes available
Type 13 (SZARRAY ): 39516 bytes
Type 15 (FREEBLOCK ): 9458748 bytes
#### Message:
11/01/2011 06:57:58: Update.DownloadUpdates() - File: Config.HEX Size: 0
GC: 10msec 282852 bytes used, 9612612 bytes available
Type 0F (STRING ): 6948 bytes
Type 11 (CLASS ): 18432 bytes
Type 15 (FREEBLOCK ): 9612612 bytes
Type 1E (BINARY_BLOB_HEAD ): 172956 bytes
Type 23 (LOCK_HEAD ): 60 bytes
Type 24 (LOCK_OWNER_HEAD ): 24 bytes
11/01/2011 06:57:59: Update.DownloadUpdates() - Files Downloading Completed
The thread '<No Name>' (0x10) has exited with code 0 (0x0).
Any idea how to fix it? Im try add:
request.Timeout = 20000;
but do not help…
