Here’s a weird one. I have other functions that do the same thing as this function…however…for some reason…this code throws an error. Not always, but when it does…it always does. Maybe the first run is okay? But then every time after the first time I get the error? Also, the function takes a long time to run, maybe 3 or 4 minutes. I don’t have any problems in a full .net visual studio console app for testing and it only takes seconds.
The catch statement which contains, “Error reading from stream reader” is where the error occurs:
public static string getifconfig()
Debug.Print("Getting ifConfig...");
string ResponseBody = string.Empty;
try
var request = (HttpWebRequest)WebRequest.Create("http://ifconfig.me/ip");
request.Method = "GET";
request.KeepAlive = false;
try
using (WebResponse response = request.GetResponse())
try
using (var reader = new StreamReader(response.GetResponseStream()))
try
ResponseBody = reader.ReadToEnd();
if (ResponseBody.Length > 0)
ResponseBody = ResponseBody.Substring(0, ResponseBody.Length - 1);
Debug.Print("Received ifConfig...");
catch (Exception e)
Debug.Print(e.Message);
Debug.Print("Error reading from stream reader");
reader.Close();
response.Close();
catch (Exception e)
Debug.Print("Error parsing ifConfig reponse after receieved");
catch(Exception e)
Debug.Print("Could not get ifconfig response...");
catch (Exception e)
Debug.Print("Could not get address from http://ifconfig.me/ip");
return ResponseBody;
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (9) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::recv [IP: 0000] ####
#### System.Net.Sockets.Socket::Receive [IP: 0018] ####
#### System.Net.Sockets.NetworkStream::Read [IP: 0062] ####
#### System.Net.InputNetworkStreamWrapper::ReadInternal [IP: 00d7] ####
#### System.Net.InputNetworkStreamWrapper::Read [IP: 000d] ####
#### System.IO.StreamReader::FillBufferAndReset [IP: 0031] ####
#### System.IO.StreamReader::ReadNonSeekableStream [IP: 0020] ####
#### System.IO.StreamReader::ReadToEnd [IP: 0016] ####
#### GadgeteerApp1.Program::getComputerIPaddresses [IP: 0036] ####
#### GadgeteerApp1.Program::ReportMyPublicIP [IP: 0019] ####
#### SocketException ErrorCode = 10060
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.dll
#### Exception System.IO.IOException - 0x00000000 (9) ####
#### Message: m_stream.Read
#### System.IO.StreamReader::FillBufferAndReset [IP: 0062] ####
A first chance exception of type ‘System.IO.IOException’ occurred in System.IO.dll
m_stream.Read
