Makla
February 27, 2013, 11:43am
1
Hi.
public static void Post()
if (Program.ethernet.IsNetworkUp)
POSTContent content = POSTContent.CreateTextBasedContent("{\"data1\": \"test\"}");
HttpRequest request = Gadgeteer.Networking.HttpHelper.CreateHttpPostRequest(@ "http://localhost/Smarthouse/Process/Microcontroler.php", content, "application/json");
request.ResponseReceived += new HttpRequest.ResponseHandler(request_ResponseReceived);
request.SendRequest();
while (!request.IsReceived)
Thread.Sleep(1000);
bool b = request.IsReceived;
static void request_ResponseReceived(HttpRequest sender, HttpResponse response)
var i = 0;
Program.ethernet is reference to J11D module. I get the IP and DNS servers. But I never get to var i = 0 or bool b = request.IsReceived line.
The basic idea is that I want to post some data to PHP.
Makla
February 27, 2013, 1:08pm
2
Maybe I have problems with setting connections.
The whole code is:
public partial class Program
if (!ethernet_J11D.Interface.IsOpen)
ethernet_J11D.Interface.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(ethernet_J11D.Interface);
ethernet_J11D.NetworkUp += new GTM.Module.NetworkModule.NetworkEventHandler(ethernet_J11D_NetworkUp);
ethernet_J11D.UseDHCP();
void ethernet_J11D_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Thread.Sleep(1000);
if (response.StatusCode == "202")
I get error:
[quote]The thread ‘’ (0x3) has exited with code 0 (0x0).
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (10) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::connect [IP: 0000] ####
#### System.Net.Sockets.Socket::Connect [IP: 001d] ####
#### System.Net.HttpWebRequest::SubmitRequest [IP: 0019] ####
#### System.Net.HttpWebRequest::GetRequestStream [IP: 0008] ####
#### SocketException ErrorCode = 10054
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.dll
#### Exception System.Net.WebException - 0x00000000 (10) ####
#### Message: connection failed
#### System.Net.HttpWebRequest::EstablishConnection [IP: 0168] ####
A first chance exception of type ‘System.Net.WebException’ occurred in System.Http.dll
An exception occured while connecting to the Internet. Please, make sure that a valid URL is used and a network connection is up.
connection failed
The thread ‘’ (0xa) has exited with code 0 (0x0).[/quote]
Makla
February 27, 2013, 3:00pm
4
HttpRequest does not have KeepAlive or Timeout.
CreateHttpPostRequest returns Gadgeteer.Networking.HttpRequest.
I double check and I can confirm that URL exists.
Same as in the other thread. Use real ip address of your server instead of localhost .
Makla
February 28, 2013, 3:37am
6
Lame, lame, lame, lame.
Thanks. I would break my head on this one.
By the way. It is also not working on 127.0.0.1. But it perfectly works on some domain.
