HttpListener exception with SSL
A mini HTTP server runs on FezDuino with success.
However I would like to secure it with TLS because most browsers refuse today to connect to insecured sources.
I implement the following code with TLS certificate and key placed inside the projects ServerResources :
_webServer = new HttpListener("https")
    HttpsCert = new X509Certificate(ServerResources.GetBytes(ServerResources.BinaryResources.servercert))
        PrivateKey = ServerResources.GetBytes(ServerResources.BinaryResources.serverkey)
When a client tries to connect to my HTTPS server this exception occurs :
#### Exception System.InvalidOperationException - CLR_E_INVALID_OPERATION (8) ####
#### Message:
#### GHIElectronics.TinyCLR.Devices.Network.Provider.NetworkControllerApiWrapper::AuthenticateAsServer [IP: 0000] ####
#### System.Net.Security.SslStream::AuthenticateAsServer [IP: 0011] ####
#### System.Net.HttpListener::AcceptThreadFunc [IP: 0096] ####
I’m looking for in “HttpListener” class the method “AcceptThreadFunc” and I see SSL Protocol is None. Is it the evidence of my exception ? What do you think ?
networkStream = new SslStream(socket);
((SslStream)networkStream).AuthenticateAsServer(m_httpsCert, SslProtocols.None);
How did you have the certificate? Is this certificate for testing?
and try with System.Security.Authentication.SslProtocols.Tls12, instead of None
sslStream.AuthenticateAsServer(your_serverCertificate, System.Security.Authentication.SslProtocols.Tls12)
Hi Dat,
I created the certificate like as mentionned on the GHI tutorial page via OpenSSL :
https://docs.ghielectronics.com/software/tinyclr/tutorials/tls-server.html
And I cannot modify sslStream because I use the HttpListener object in GHIElectronics.TinyCLR.Networking.Http. This sslStream is created and set up in “AcceptThreadFunc” method…
Could you add to github issue and we will look into asap?
It has been fixed
