GHIElectronics.NETMF.Hardware.InternalFlashStorage
and
GHIElectronics.NETMF.Hardware.Configuration.PermanentUserKey
Where are these classes?
I’m usinf Fez Cobra 2 and sdk 4.2 but i do not see where i can use these libraries?
and
FYI: Google is a great resource for searching for class names. The links you want are:
You will note these are from the 4.1 SDK. The APIs for the 4.2 SDK are linked to from https://www.ghielectronics.com/support/.net-micro-framework
Thanks Jeff…what do you mean by “The APIs for the 4.2 SDK are linked to from https://www.ghielectronics.com/support/.net-micro-framework…”
There were only available in older SDKs, dropped in netmf 4.2
@ anthonys - The links I sent were for the outdated 4.1. On the page linked to by the URL I posted, there is a section “API References” that has links to the current (4.2) class documentation.
I assume i have to use ExtendedWeakReference instead?
Depends on your program, but that is one way to store values between resets.
