See reply 22. Adhoc is a bad idea with mobile devices
@ SkierHiker - Wish you luck ;-)⦠For ADHOC mode at your Cobra set your IP address to start with 169.254. Then you will be able to communicate with your PC or an Apple device. Android device are more tricky⦠One will work, others wonāt⦠I had some android devices working by manually set their WiFi settings. When a Windows PC is connected to your ADHOC device it will try to obtain a IP address using DHCPā¦(if obtain DHCP ⦠is enabled). Since DHCP is not working in adhoc mode⦠it will not receive an IP address and automatically falls back to an IP in the range 169.254.x.x Once the PC is using this fall back IP it will work perfectly.
I donāt quite buy that Gus⦠the AR Parrot quadcopters use ad-hoc just fine with mobile devices.
@ Gus -
I think Google agrees with you since they implement WiFi Direct. Any thoughts of GHI getting onto the WiFi Direct bandwagon? I think youāre going to find that more and more people are becoming interested in controlling their gadgets directly with their iPhones and WiFi is the only easy option. Bluetooth on an Apple device requires their special security chip which they charge a license fee.
And Iām still wondering how GoPro uses WiFi with Android phones.
Maybe that is the case but when we tried it we had all kind of problems. Also, one of our customers had similar problems as well.
@ RobvanSchelven -
I tried your RunServer but Iām unable to communicate with my browser. Even Ping does not work. The only difference is that Iām using the on-board WiFi on the Cobra-II. I figure thereās no point in trying to get it to talk TCP until I can get HTTP to work. Here is my code. Any suggestions?
private static InterruptPort IntButton = new InterruptPort((Cpu.Pin)G120.Pin.P0_22, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeBoth);
private static Boolean DoOnce = false;
private static SPI.SPI_module SPIModule = SPI.SPI_module.SPI2;
private static Cpu.Pin ChipSelect = G120.Pin.P1_10;
private static Cpu.Pin ExtInterrupt = G120.Pin.P2_11;
private static Cpu.Pin Reset = G120.Pin.P1_9;
private static UInt32 ClockRate = 4000;
private static String SSID = "TestWiFi";
private static SecurityMode SecurityType = SecurityMode.Open;
private static String SecurityKey = "";
private static UInt32 WiFiChannel = 10;
private static String IPAddress = "169.254.0.200";
private static String SubNetMask = "255.255.0.0";
private static String Gateway = "169.254.0.1";
try
Thread.Sleep(5000); // allow MFDeploy to start
IntButton.OnInterrupt += new NativeEventHandler(IntButton_OnInterrupt);
WiFiRS9110 WiFi = new WiFiRS9110(SPIModule, ChipSelect, ExtInterrupt, Reset, ClockRate);
if (!WiFi.IsOpen)
WiFi.Open();
WiFi.StartAdHocHost(SSID, SecurityType, SecurityKey, WiFiChannel);
WiFi.NetworkInterface.EnableStaticIP(IPAddress, SubNetMask, Gateway);
WiFi.WirelessConnectivityChanged += new WiFiRS9110.WirelessConnectivityChangedEventHandler(WiFi_Changed);
catch (Exception ex)
Debug.Print("Main Exception=" + ex.ToString());
static void IntButton_OnInterrupt(uint port, uint state, DateTime time)
if (!DoOnce)
DoOnce = true;
RunServer();
private static void WiFi_Changed(object sender, WiFiRS9110.WirelessConnectivityEventArgs e)
Debug.Print("isConnected = " + e.IsConnected);
Debug.Print("Info = " + e.NetworkInformation); // this is null
internal static void RunServer()
try
Debug.Print("Starting HTTP Server");
HttpListener listener = new HttpListener("http");
listener.Start();
HttpListenerResponse response = null;
HttpListenerContext context = null;
try
Debug.Print("Waiting for HTTP Response");
context = listener.GetContext();
response = context.Response;
Debug.Print("Received HTTP Response");
HttpListenerRequest request = context.Request;
switch (request.HttpMethod.ToUpper())
case "GET": ProcessClientGetRequest(context); break;
if (response != null)
response.Close();
if (context != null)
context.Close();
Debug.Print("RunServer Exception=" + ex.ToString());
private static void ProcessClientGetRequest(HttpListenerContext context)
try
Debug.Print("Processing HTTP Client Request");
HttpListenerResponse response = context.Response;
Byte[] outBuffer = Encoding.UTF8.GetBytes("Hello World");
Debug.Print("HTTP URL=" + request.RawUrl);
response.OutputStream.Write(outBuffer, 0, outBuffer.Length);
Debug.Print("ProcessClientGetRequest Exception=" + ex.ToString());
@ SkierHiker - add NetworkInterfaceExtension.AssignNetworkingStackTo(WiFi); after WiFi.Open(ā¦)
@ RobvanSchelven -
The good news is that did the trick! The bad news is that I was planning on taking the afternoon off but now Iām on a mission :).
@ SkierHiker - Live is not easy⦠sometimes
Good Luck
