I’d like to use the Wifi RS21 to set up an ad-hoc network (that is, as an ad-hoc access point). All the examples I’ve been able to find, show how to use the wifi module to attach to an AP.
From looking at the methods provided, it seems that I can’t do the AP end of things…
Any input on how to make that work the way I’d like? Samples, etc are greatly appreciated…
To Mike: I thought I mentioned that I was using the Wifi RS21. Is that not the device? (Please be kind, as I’m just learning the lingo around here. :-))
To Architect: Interesting thread, thanks for the pointer, however (and forgive me if I missed something) when I instantiated the wifi module, I didn’t see anything like a function that would allow me to set up an ad hoc network…
No, but I will and thanks. There are lots of little pieces that I’m still figuring out. One I do wish was better was docs explaining all the functions and variables in a module.
Great! I would like to encourage you to contribute as well. If you make something working and there is no existing examples for that you can share the whole projects on Codeshare or write articles and tutorials on wiki.
Looks like this one need some update since the module driver has changed a lot:
to try to name my network MyNet as an open net with no key and on channel 6.
I got this:
A first chance exception of type ‘GHI.Premium.Net.NetworkInterfaceExtensionException’ occurred in GHI.Premium.Net.dll
An unhandled exception of type ‘GHI.Premium.Net.NetworkInterfaceExtensionException’ occurred in GHI.Premium.Net.dll
so I can only assume that it wants more from me, but I don’t know what…
First of all please use (you can edit your post above with pencil button) code button to surround your code with code tags or do it manually. That way it is nicely formatted and easier to read.
You can put a breakpoint inside your event handler. The while running under VS debugger you will be able to examine the object when it will hit the breakpoint.
Thanks for the hint on the code. Sorry to have not seen that earlier.
And, I’m still getting used to the VC interface (I’m a linux hack usually, so I’m more familiar with gdb. Fortunately this is quite analgous.
e.NetworkInformation is null, so that’s not terribly helpful.
Maybe @ RobvanSchelven can provide more info.
GENERAL RANT ABOUT DOCUMENTATION:
it seems like help has become simply a restatement of data and often misses the information about hwo to use that data. When I worked in chip design, we spent enormous amount of time making sure that we carefully explained not only what the bits in a register meant, but how they interacted and how to use the block we were describing.
GENERAL RANT MODE OFF
Do not think I’m ungrateful. I am. Very! but I’m frustrated that I’m not easily able to find some of this information out myself. Given a reference manual/guide I would go pore over that - but I haven’t really found one.
Having said that, I’m having great fun with the spider board…
