Hello everybody,
I’d like to know how to use the SPI Liaison cerberus. I was inspired by an example of GHI tutorial but it does not work. I’d like your help to find out where that I have made a mistake in my code. I have two fez cerberus. One master and one slave. It has both the same code.
Thank you.
using System.Collections;
using System.Text;
using Microsoft.SPOT.Touch;
using System.IO.Ports;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using GTI = Gadgeteer.Interfaces;
namespace LiaisonSpiTest_Esclave_
public partial class Program
private static GTI.SPI _spi;
private static GTI.SPI.Configuration _config;
private static GT.Socket _socket;
private static byte[] writeBuffer, readBuffer;
timer.Tick +=<tab><tab>
timer.Start();
_socket = GT.Socket.GetSocket(5, true, null, null);
_config = new GTI.SPI.Configuration(false, 0, 0, false, true, 2000);
_spi = new GTI.SPI(_socket, _config, GTI.SPI.Sharing.Exclusive, _socket, GT.Socket.Pin.Six, null);
writeBuffer = new byte[5] { 83, 80, 73, 81, 75 };
readBuffer = new byte[5] ;
GT.Timer timer = new GT.Timer(100);
_spi.WriteRead(writeBuffer, readBuffer);
