How to use LDR as button
I have the Panda II and I know this is a simple question, but when trying to assign an Input port as the LDR button, the pin is not recognized. I tried using EINT0 and P210.
I just want the LED to be controlled by the button
Code is shown below
namespace FEZ_Panda_II_Application2
            OutputPort LED;
            InputPort Button;
            OutputPort led = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, true);
            Button = new InputPort((Cpu.Pin)FEZ_Pin.Digital.EINT0, false, Port.ResistorMode.PullUp);
                LED.Write(Button.Read());
                Thread.Sleep(10);
Does this work for you?
Button = new InputPort((Cpu.Pin)FEZ_Pin.Digital.LDR, false, Port.ResistorMode.PullUp);
If this does not work, then you might not have defined your project as a Panda II application.
Yes! Guess I was over thinking… : )
