I have a FEZ Spider which I recently purchased to for a dedicated one off application. This involves capturing a substantial quantity of analogue data, processing it, and displaying the results in graphical form to the user in near real time.
The data capture is handled by a dedicated processor connected to the FEZ spider via I2C. When sent the data consists of a stream with the following structure:-
typedef struct {
unsigned char status1; //1
unsigned char status2; //1
short adc[5]; //10
int time_stamp; //4
} RT_INPUT_SET_t;
I hope to send several hundred at a time and I want to efficiently format them so that they can be quickly processed. The issue I have is that on input the IC2 data is a byte array and I would like to overlay my structure in the way of a C union. In the full C# this can be done using System.Runtime.InteropServices.StructLayout(LayoutKind.Explicit but under the micro framework FieldOffset is not implemented.
Surely there must be a quicker way than copying the incoming data byte by byte into a new structure?
[italic]
For the record I am an experienced real time programmer but this was gained many many years ago.
[/italic]
