hi,gus. the firmware of spider in my hand is 4.1.6, and now i have download your new sdk and installed . so, i need to upgrade the firmware . but when i use your spider mainboard it seems not work for you :
confusing, in step 1, it reminds to :" spider mainboard updater will use the tinybooter file in the following location", but the file in default is firmware files ; and the “will use the firmwares files in the following location”,but the file in default is tinybooter files:tinybooter.GHI.
in step 2, set the jumper as the picture(1/2/3: on and 4:off) and then it reminds me : can not connect to the device! follow steps 1 to 2. in the hardware management , it seems the dirver of virtural com is not installed , just a “EMX” device. when i want to install the driver mannully in the 4.1 SDK\USB Drivers\GHI_Bootloader_Interface, it reminds me driver installation error.
do you have any suggestion ?
thanks.
aother question is after i upgrade the firmware of spider and SDK(4.1.7) on PC, i have a app that include a lib (build in sdk 4.1.6), as mentioned on the “Assembly/Firmware Matching”, do i need to rebuild the lib in sdk 4.1.7?
now , i have upgrade the firmware to 4.1.7 without upgrade the tinybootloader because of driver problem, and then i want to build and deploy an app that once works before i do all of this , but it reminds me :
Assembly: GTM.GHIElectronics.Camera (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.USBHost’ (4.1.6.0)
Assembly: GTM.GHIElectronics.Camera (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.System’ (4.1.6.0)
does it means the driver build in 4.1.6 can not be used in the 4.1.7?
with no sucess on updated to 4.1.7SDK , i try to uninstall the SDK and install my 4.1.6 SDK again . so , i deploy my 4.1.6 firmware (CLR.hex/ CLR2.hex/ and config.hex), it shows the result:
Pinging... TinyCLR
HalSystemInfo.halVersion: 4.1.2821.0
HalSystemInfo.halVendorInfo: Microsoft Copyright (C) Microsoft Corporation. All rig
HalSystemInfo.oemCode: 255
HalSystemInfo.modelCode: 0
HalSystemInfo.skuCode: 65535
HalSystemInfo.moduleSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
HalSystemInfo.systemSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
ClrInfo.clrVersion: 4.1.2821.0
ClrInfo.clrVendorInfo: Microsoft Copyright (C) Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion: 4.1.2821.0
SolutionReleaseInfo.solutionVersion: 4.1.6.0
SolutionReleaseInfo.solutionVendorInfo: GHI Electronics, LLC
SoftwareVersion.BuildDate: Jun 30 2011
SoftwareVersion.CompilerVersion: 410561
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 320
LCD.Height: 240
LCD.BitsPerPixel: 16
AppDomains: True
ExceptionFilters: True
IncrementalDeployment: True
SoftReboot: True
Profiling: False
ProfilingAllocations: False
ProfilingCalls: False
IsUnknown: False
Connecting to EMX_EMX...Connected
the screen shows :waiting for debug commands.
but as i deploy the app that once works in 4.1.6, it shows : Device not found or cannot be opened - USB:Gadgeteer
i do not know why now.
ps: the vs2010 has set to : transpent: USB ;device: EMX_EMX
