Rebooting…
Done.
Create TS.
Loading start at 4e13c, end 56314
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
AssemblyRef = 0 bytes ( 0 elements)
TypeRef = 0 bytes ( 0 elements)
FieldRef = 0 bytes ( 0 elements)
MethodRef = 0 bytes ( 0 elements)
TypeDef = 1112 bytes ( 139 elements)
FieldDef = 272 bytes ( 135 elements)
MethodDef = 1572 bytes ( 786 elements)
Attributes = 0 bytes ( 0 elements)
TypeSpec = 16 bytes ( 4 elements)
Resources = 232 bytes ( 29 elements)
Resources Files = 16 bytes ( 2 elements)
Resources Data = 437 bytes
Strings = 1551 bytes
Signatures = 2126 bytes
ByteCode = 11702 bytes
Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.1.2821.0) (740 RAM - 4620 ROM - 2522 METADATA)
AssemblyRef = 12 bytes ( 3 elements)
TypeRef = 76 bytes ( 19 elements)
MethodRef = 112 bytes ( 28 elements)
TypeDef = 120 bytes ( 15 elements)
FieldDef = 72 bytes ( 35 elements)
MethodDef = 140 bytes ( 70 elements)
TypeSpec = 0 bytes ( 0 elements)
Resources = 0 bytes ( 0 elements)
Resources Files = 0 bytes ( 0 elements)
Resources Data = 0 bytes
Strings = 676 bytes
Signatures = 350 bytes
ByteCode = 1295 bytes
Assembly: FEZDomino_GHIElectronics.NETMF.FEZ (4.1.3.0) (304 RAM - 900 ROM - 495 METADATA)
TypeRef = 44 bytes ( 11 elements)
MethodRef = 20 bytes ( 5 elements)
TypeDef = 72 bytes ( 9 elements)
FieldDef = 12 bytes ( 6 elements)
MethodDef = 4 bytes ( 2 elements)
Strings = 178 bytes
Signatures = 35 bytes
ByteCode = 98 bytes
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) (1752 RAM - 11440 ROM - 7371 METADATA)
AssemblyRef = 8 bytes ( 2 elements)
TypeRef = 124 bytes ( 31 elements)
FieldRef = 24 bytes ( 6 elements)
MethodRef = 120 bytes ( 30 elements)
TypeDef = 496 bytes ( 62 elements)
FieldDef = 176 bytes ( 88 elements)
MethodDef = 444 bytes ( 222 elements)
Strings = 1329 bytes
Signatures = 1067 bytes
ByteCode = 2611 bytes
Assembly: My HHO code for FEZ Domino (1.0.0.0) (1156 RAM - 11584 ROM - 3730 METADATA)
AssemblyRef = 36 bytes ( 9 elements)
TypeRef = 224 bytes ( 56 elements)
FieldRef = 12 bytes ( 3 elements)
MethodRef = 296 bytes ( 74 elements)
TypeDef = 160 bytes ( 20 elements)
FieldDef = 100 bytes ( 49 elements)
MethodDef = 128 bytes ( 64 elements)
TypeSpec = 4 bytes ( 1 elements)
Resources = 16 bytes ( 2 elements)
Resources Files = 8 bytes ( 1 elements)
Resources Data = 13 bytes
Strings = 3313 bytes
Signatures = 658 bytes
ByteCode = 4355 bytes
Assembly: System (4.1.2821.0) (872 RAM - 5992 ROM - 3206 METADATA)
MethodRef = 172 bytes ( 43 elements)
TypeDef = 144 bytes ( 18 elements)
FieldDef = 56 bytes ( 28 elements)
MethodDef = 184 bytes ( 92 elements)
Strings = 21 bytes
Signatures = 546 bytes
ByteCode = 2635 bytes
Assembly: GHIElectronics.NETMF.USBHost (4.1.3.0) (1528 RAM - 14664 ROM - 6396 METADATA)
TypeRef = 88 bytes ( 22 elements)
MethodRef = 88 bytes ( 22 elements)
TypeDef = 336 bytes ( 42 elements)
FieldDef = 260 bytes ( 130 elements)
MethodDef = 396 bytes ( 198 elements)
Strings = 3625 bytes
Signatures = 764 bytes
ByteCode = 4514 bytes
Assembly: GHIElectronics.NETMF.IO (4.1.3.0) (212 RAM - 664 ROM - 289 METADATA)
TypeRef = 12 bytes ( 3 elements)
FieldRef = 8 bytes ( 2 elements)
MethodRef = 4 bytes ( 1 elements)
TypeDef = 8 bytes ( 1 elements)
FieldDef = 4 bytes ( 2 elements)
MethodDef = 20 bytes ( 9 elements)
Strings = 212 bytes
Signatures = 33 bytes
ByteCode = 36 bytes
Assembly: Microsoft.SPOT.Net (4.1.2821.0) (704 RAM - 5060 ROM - 2452 METADATA)
TypeRef = 96 bytes ( 24 elements)
MethodRef = 76 bytes ( 19 elements)
FieldDef = 60 bytes ( 29 elements)
MethodDef = 136 bytes ( 68 elements)
Strings = 1280 bytes
Signatures = 388 bytes
ByteCode = 1204 bytes
Assembly: Microsoft.SPOT.Native (4.1.2821.0) (1144 RAM - 6516 ROM - 4479 METADATA)
AssemblyRef = 4 bytes ( 1 elements)
TypeRef = 80 bytes ( 20 elements)
MethodRef = 60 bytes ( 15 elements)
FieldDef = 192 bytes ( 95 elements)
MethodDef = 224 bytes ( 111 elements)
Attributes = 48 bytes ( 6 elements)
Resources = 72 bytes ( 9 elements)
Resources Data = 747 bytes
Strings = 648 bytes
Signatures = 595 bytes
ByteCode = 418 bytes
Assembly: System.IO (4.1.2821.0) (1548 RAM - 13292 ROM - 5862 METADATA)
TypeRef = 168 bytes ( 42 elements)
FieldRef = 36 bytes ( 9 elements)
MethodRef = 392 bytes ( 98 elements)
FieldDef = 76 bytes ( 37 elements)
MethodDef = 392 bytes ( 195 elements)
TypeSpec = 8 bytes ( 2 elements)
Strings = 356 bytes
Signatures = 790 bytes
ByteCode = 6946 bytes
Assembly: GHIElectronics.NETMF.Hardware (4.1.3.0) (856 RAM - 5232 ROM - 3195 METADATA)
TypeRef = 36 bytes ( 9 elements)
MethodRef = 44 bytes ( 11 elements)
TypeDef = 240 bytes ( 30 elements)
FieldDef = 92 bytes ( 46 elements)
MethodDef = 200 bytes ( 99 elements)
Strings = 1413 bytes
Signatures = 339 bytes
ByteCode = 494 bytes
Assembly: GHIElectronics.NETMF.System (4.1.3.0) (440 RAM - 2220 ROM - 1281 METADATA)
MethodRef = 48 bytes ( 12 elements)
FieldDef = 28 bytes ( 13 elements)
MethodDef = 72 bytes ( 36 elements)
Strings = 496 bytes
Signatures = 181 bytes
ByteCode = 314 bytes
Resolving.
Total: (13168 RAM - 115420 ROM - 60412 METADATA)
AssemblyRef = 144 bytes ( 36 elements)
TypeRef = 1060 bytes ( 265 elements)
FieldRef = 92 bytes ( 23 elements)
MethodRef = 1432 bytes ( 358 elements)
TypeDef = 3360 bytes ( 420 elements)
FieldDef = 1400 bytes ( 693 elements)
MethodDef = 3912 bytes ( 1952 elements)
DebuggingInfo = 1968 bytes
TypeSpec = 36 bytes ( 9 elements)
Resources Files = 96 bytes ( 4 elements)
Resources = 320 bytes ( 40 elements)
Resources Data = 1197 bytes
Strings = 15098 bytes
Signatures = 7872 bytes
ByteCode = 36622 bytes
Ready.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll”, Cимволы загружены.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll”, Cимволы загружены.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll”, Cимволы загружены.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.IO.dll”, Cимволы загружены.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\FEZDomino_GHIElectronics.NETMF.FEZ.dll”
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.Hardware.dll”
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.System.dll”
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.IO.dll”
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.IO.dll”, Cимволы загружены.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.USBHost.dll”
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Users\Viktor\Documents\Visual Studio 2010\Projects\My HHO code for FEZ Domino\My HHO code for FEZ Domino\bin\Debug\le\My HHO code for FEZ Domino.exe”, Cимволы загружены.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Net.dll”, Cимволы загружены.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Управляемый код): Загружен “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.dll”, Cимволы загружены.
Поток ‘<Без имени>’ (0x2) завершился с кодом 0 (0x0).
Getting device’s RTC: 01/19/2011 07:04:39
Retrieving reset RTC: 01/19/2011 07:04:39
Found 1 OneWire thermometer.
GC: 3msec 45720 bytes used, 18660 bytes available
Type 0F (STRING ): 180 bytes
Type 11 (CLASS ): 2340 bytes
Type 12 (VALUETYPE ): 60 bytes
Type 13 (SZARRAY ): 1008 bytes
Type 15 (FREEBLOCK ): 18660 bytes
Type 16 (CACHEDBLOCK ): 180 bytes
Type 17 (ASSEMBLY ): 15204 bytes
Type 18 (WEAKCLASS ): 48 bytes
Type 19 (REFLECTION ): 24 bytes
Type 1B (DELEGATE_HEAD ): 756 bytes
Type 1C (DELEGATELIST_HEAD ): 144 bytes
Type 1D (OBJECT_TO_EVENT ): 240 bytes
Type 1E (BINARY_BLOB_HEAD ): 5784 bytes
Type 1F (THREAD ): 1920 bytes
Type 20 (SUBTHREAD ): 240 bytes
Type 21 (STACK_FRAME ): 15936 bytes
Type 22 (TIMER_HEAD ): 72 bytes
Type 27 (FINALIZER_HEAD ): 168 bytes
Type 31 (IO_PORT ): 108 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 1236 bytes
GC: 3msec 59904 bytes used, 4476 bytes available
Type 11 (CLASS ): 2532 bytes
Type 15 (FREEBLOCK ): 4476 bytes
Type 1B (DELEGATE_HEAD ): 792 bytes
Type 1D (OBJECT_TO_EVENT ): 312 bytes
Type 1E (BINARY_BLOB_HEAD ): 5892 bytes
Type 1F (THREAD ): 2304 bytes
Type 20 (SUBTHREAD ): 288 bytes
Type 21 (STACK_FRAME ): 29400 bytes
Type 27 (FINALIZER_HEAD ): 192 bytes
Type 31 (IO_PORT ): 144 bytes
Поток ‘<Без имени>’ (0x1) завершился с кодом 0 (0x0).
GC: 3msec 59628 bytes used, 4752 bytes available
Type 11 (CLASS ): 2292 bytes
Type 15 (FREEBLOCK ): 4752 bytes
Type 16 (CACHEDBLOCK ): 192 bytes
Type 1D (OBJECT_TO_EVENT ): 120 bytes
Type 1E (BINARY_BLOB_HEAD ): 5916 bytes
Type 21 (STACK_FRAME ): 29808 bytes
GC: 3msec 60252 bytes used, 4128 bytes available
Type 15 (FREEBLOCK ): 4128 bytes
Type 21 (STACK_FRAME ): 30624 bytes
Failed allocation for 17 blocks, 204 bytes
GC: 3msec 60312 bytes used, 4068 bytes available
Type 11 (CLASS ): 2352 bytes
Type 15 (FREEBLOCK ): 4068 bytes
Failed allocation for 96 blocks, 1152 bytes
GC: 3msec 60204 bytes used, 4176 bytes available
Type 15 (FREEBLOCK ): 4176 bytes
Type 1E (BINARY_BLOB_HEAD ): 5808 bytes
Failed allocation for 39 blocks, 468 bytes
GC: 3msec 60672 bytes used, 3708 bytes available
Type 15 (FREEBLOCK ): 3708 bytes
Type 1E (BINARY_BLOB_HEAD ): 6276 bytes
Failed allocation for 191 blocks, 2292 bytes
