I’m wondering what would be the best way to see when an irrigation system is sending 24 volt AC down a specific zone so that I can run some logic in my Fez Domino.
Thanks,
Brent…
Thanks,
Brent…
Or you can do it by yourself
Here is a small schematics for 230V(you have to tweak a little bit)
It’s also cheaper maybe 3-4$ , the module costs about 17$
Thanks guys.
@ logitechs . Do you know exactly what part I should order at that site. I’m a bit of a a newb with this hardware stuff but I’m learning fast
Brent…
Hmmm,
I think one of these module should work.
http://www.crydom.com/en/Products/Catalog/sm_input_modules.pdf
SM-IDC5 or SM-IDC5N
The difference between both modules is the turn-on/off time (SM-IDC5 is faster) and input voltage
But both modules are in the input voltage range you need.
