is it possible to show up a modified driver in VisualStudio Tools without creating it from scratch?
I modified the rfid driver from ghi to use it with the ID-20LA. The class is now called ID20_RFIDReader. So i created a new directory in the folder where the original driver is placed ( GHI Electronics\GHI .NET Gadgeteer SDK\Modules, put new files in it, modified the gadgeteerhardware.xml but of course, no new module showed up in the VisualStudio Tools.
What do i have to to to bring up the new module in the tools?
Greetings
Chris
Hi Chris,
you would need to build the full driver package - not insurmountable, but also not straightforward. You can read the details in the module builders guide. http://gadgeteer.codeplex.com/releases/view/105388
Thanks Brett,
i hoped i could avoid this.
So i build the module from scratch with the module template and the installer worked as expected.
Greetings
Chris
