I have a window with a number text boxes and text blocks.
I want to be able to show and hide them on the fly with the screen still visible. At present if I hide then during creating the window they don’t show.
If I try to make it invisible with the screen current, they do not clear.
Is it possible to do this without drawing a bitmap over them?
You have to draw over that area.
Maybe use
// In case the screen is re-rendered or the area is touched
myTextbox.Visible = false;
// This will only redraw the area the TextBox occupies with the background color or graphic.
Glide.Flush(myTextbox.Rect);
That almost works. I found I had to use the following prior to the Flush call.
CurrentWindow.Graphics.DrawRectangle(myTextbox.Rect, CurrentWindow.BackColor, 255);
